2 BAR SD Timing Table...
Old May 24, 2010 | 11:48 AM
Turbo 6.0's Avatar
Default 2 BAR SD Timing Table...
What does the PCM use to calculate airmass on a HP Tuners 2bar operating system?
Old May 24, 2010 | 03:09 PM
Frost's Avatar
basically MAP, IAT, ECT, and RPM, but I'm not sure if that's what you actually asking about.
Old May 24, 2010 | 03:22 PM
Turbo 6.0's Avatar
I am running in the bottom row of my timing table @ 8psi boost and I want to get it back up in the middle. I rescaled my MAF curve which shows it running @1.00 G/CYL @ 8psi but it's not giving me the timing I command. It seems like it's still running in the bottom row but it's plotting higher up in the histogram...
Hope that made sense...
Old May 24, 2010 | 04:43 PM
foff667's Avatar
LS1TECH Sponsor
They are calculated by the VE table, the pid in the scanner is a calculation g/cyl=ve*map/iat just keep in mind the ve table is normalized by a factor to give you a percentage.
Old May 24, 2010 | 05:02 PM
Turbo 6.0's Avatar
So am I stuck with running in the bottom row of the timing table?
Old May 24, 2010 | 05:54 PM
foff667's Avatar
LS1TECH Sponsor
You likely could adjust the ifr/ve tables so that you are out of the last row.
Old May 24, 2010 | 05:59 PM
Turbo 6.0's Avatar
Of course Trying that now...
Old May 24, 2010 | 08:31 PM
Frost's Avatar
Besides that, if you ran much higher boost, you could scale your injector and airflow settings.
Often a much easier approach is using an AFR spark modifier. Here is an example of how to set that up: http://www.hptuners.com/forum/showpo...8&postcount=11
Old May 24, 2010 | 08:41 PM
bad6as's Avatar
hey quick question, whats my target a/f ratio?
Old May 24, 2010 | 11:48 PM
Frost's Avatar
Your boost is very low (like 3-4 psi for now) so as long as you are under 12, everything is fine. I am just being general because I don't have your file here on this laptop. It seems to me that it was around 11.4-11.6 the day we worked on it, but I don't recall 100%.
If you send me an email ans ask me to check logs and let you know what the deal was on that day, I'll have a look and let you know. I just got back form vacation late this afternoon though, and have about another 300 or so emails to answer to be back up to date.
Old May 25, 2010 | 04:22 AM
10sec_rx7's Avatar
7 Second Club
yep thats what i do with LS1's works a treat
Old May 25, 2010 | 09:57 AM
Turbo 6.0's Avatar
I also use that table for a over-boost protection. I just put in -20 degrees whenever I am commanding 1.4 EQ ratio (or richer). Then I went to the boost enrichment and set the commanded AFR to 1.4 @ 170 KPA & up. If I over boost then it will pull the 20 degrees out hopfully keeping it together...
Old May 25, 2010 | 09:59 AM
Turbo 6.0's Avatar
Set that up last night and it worked great! I took 30% out of the IFR and the VE and now @ 8 psi I am at about 1.00 G/CYL in the timing table.
