Holley hp and dominator efi ecu for LSX
Anyone tried it yet? Looks pretty sweet so far. The price is a little high but one could expect it to drop after being out for a little while.
Im curious as to how accurate the "self tuning" feature could possibly be..? Of course I would probly just use that feature to set a base tune, then modify it but it looks verry user friendly.
They say that the Hp version is plug and play for a lsx engine but it looks as if you have to buy the ECU, injector wireing harness then the ignition harness seperatly?
http://www.holleytv.com/video_detail.php?mId=13192
LS1Tech Co-Founder
Folks are running these systems now and I think so far that the most power made with it has been 1700 HP. While there have been some really ECU products over the years, I think these guys today probably have the best combination of DIY usability and tech support. If you are interested in best pricing I can poke around see who on here is strong dealer for them.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
PS, I've tuned a whole bunch of different standalones, and this looks like the nicest one yet.
I'm looking to go dual fuel and pro street an old vette drag car
I want to run pump gas on the primary injectors and e85 on the secondary injectors with a twin turbo setup
it's currently an alchy car and already has a front and rear fuel cell so it's a good candidate
looking for the best pricing and folks that might have experience with the tuning
I'll put together the twin turbo and run 10-1 compression. looking for something that can crooze on low timing and pump gas and ramp up fuel/the timing on e85 bringing the big secondaries online from the secondary e85 injectors and fuel system when the boost hits. I'll brew up my own e85 to get a consistent blend. need to make sure I have a wideband to help make sure all this fancy stuff actually works and the efi dominator looks good
initially I'll run the old turbo 400 with the brake, but eventually want to control a 4L80E too once I can afford to build one
I have the engine built, it's a 496 the 82 drag car has a chassis to support up to 2k hp
looking to make around 1400 or so very streetable hp as that's probably the limit for the engine to stay "relatively low maint"
ed,
let me know, I'm in alex va and have the LSV ZR-1 we talked about running on e85
this really looks like the hot ticket using the dominator efi for what I want to do
need to sell my old turbo buick first, then I can step up and street the old drag car
I'll also have a 13-1 468 chevy race motor for sale it pulls a 2900 lb vette to 9.20s at 142 with a 1.36 60 ft time.
lemmeknow, might have a customer down the road for me in order to come up with the fold to pay U!! thx
ed,
ed,
lemmeknow, might have a customer down the road for me in order to come up with the fold to pay U!! thx![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
ed,
Keep us informed on your progress.
ive had the hp kit on my car now for a couple of months . but for a few issues, it is money well spent.
pros:
+ 31x31 table for fuel and spark.
+ real time tuning on everything
+ self learn and closed loop correction, means my tuner who had never used it before was able to rough in a tune in 15 minutes.
+ comes with a harness and o2 sensor for the $1500. it is only a little bit more expensive than a harness, pcm and hptuners/efilive
+ well laid out and easy to understand
+ built in nitrous and water meth control
cons
- advertised boost control feature is not implemented yet
- it does not work with ls1 factory gauges so if you want gauges you will spend $100 for each holley gauge you want. there is a guy who has 14 gauges so thats $1400 extra he spent on the gauges
- I cant find a rhyme or reason for why the closed loop/learn sometimes just deactivates and reactivates itself
- the datalogger AND the datalog viewer are lacking.
pros:
cons
I'm in the process of installing the dominator and dyno tuning an blown ls1. Software is nice but instructions are non existent. Haha until you call the right tech guy. All of the wiring schematics are in the program under help tab. Along with setting it up etc. Unfortunately I think we found them to late and fried the ecu tonight. I'll see what they say in the morning. All the add ons will nickel and dime you. Oh the power cable for the dominator and hp are an add on.
Now that i've cooled off. I would like to say also buy it straight through Holley and not a shop like i did. That way all the harnesses, power cable etc you'd know about. After looking on Holley website and printing off the selection guide would have saved me one headache. Read through all manuals 1st before trying to run it. I'm sure it's a excellent setup and will post more after i get the ECU figured out.
Holley don't think the ECU is damaged and trying to trouble shoot. We keep blowing the 20amp fuse for the relay that supplies power to the fuel pump, injectors and coils. The fuel pump wire is not hook up, engine has spark, and injectors won't pulse. unhook the injector harness and fuse don't blow so we have it narrowed down to ECU or Injectors? I want to say the tech support is amazing. they really are there to help you.
I'm Just adding to the List...
and adding a suggestion for a few of the issues listed here in this thread so far
I'm Using the Holley Dominator..mods in Signature.
The Nitrous kit will happen soon....very soon.
100% of engine control goes thru the Holley
100% of Nitrous control will go thru the Holly...it can do up to 4 stages plus Purge... I'll be doing 2 stages plus purge..
My trans is a TCI 6x, which has its own controller.
Honestly, if you are going to buy this thing, you dont want the slow *** ls1 gauge cluster anyways...
I replaced every cluster gauge, + added a Trans temp gauge and a $300 Digital LED readout Trans Gear Gauge that reads CanBus for its data
and spent $1200
Try Checking your Fuel Modifiers... ECT..Coolant temp enrich%
Pretty Much anything that does not equate to 100% will turn off learning
You have too many things on that small 20 amp fuse..
secondly possibly also too small of wire which generates hear which will cause the fuse to blow as well
Each item you listed should have its own 20 amp fuse, or you sould have one larger fuse to take care of it.(preferably 3 individual fuses so you can troubleshoot when one has a problem...then it only blows the one fuse of the item that has issues making it obvious where to start looking)
and spent $1200
I have two of the HP kits
My car is working great. went 10.00 first pass the tuning was a 10 mile drive on the streets of bowling green.
11 passes later went 9.66. No dyno just using the closed loop feedback.
Installing one on dads daily driver chevelle now. Had it powered up and everthing works perfect.
If you are looking for gauges just get the touch screen it is great. Don't even have the laptop in the car for other than downloading data and making tune up changes
Tim
Tim
