random missfire codes
Old Jan 18, 2004 | 03:20 AM
seadog's Avatar
Question random missfire codes
hey guys I am getting misfires in cylinders 7 and 2 and I have changed about everthing i can think of but they aren't going away. I checked the plugs, wires and even the coils and i am still getting a lot of misfires. The truck runs great is the wierd thing. It feels like it may being missing a little when it first starts but after it warms up it idles fine. I don't understand it. Anybody have any ideas?
Old Jan 18, 2004 | 07:40 AM
JoSeY's Avatar
LS1 edit and desensitive them or do like I did and toally get rid of them...unless ur spraying, then just desensitze them...
Old Jan 18, 2004 | 07:57 PM
2000silverbullet's Avatar
I had the same problem, and changed everything just as you have. I found out that my gasket between the intake manifold and heads was torn. I replaced it and the problem was gone. Try that or GM top engine cleaner. Any GM dealership can do it for about $75.00. Ensure that they do the GM top engine clean and nothing else.
Old Jan 18, 2004 | 09:05 PM
seadog's Avatar
alright i will have to try that. Which of your cylinders were missing when you had to change your gaseket. That sounds logical to me because sometimes i get codes in other cylinders too but just minor ones.
Old Jan 19, 2004 | 10:30 AM
My missfire was on 1 & 8. There were little ones on other cylinders as well. After doing GM top cleaner and changing intake gasket all was good. Except my idle...... but when you fix something on a LS1, something else seems to go wrong..... Good luck.
Old Jan 19, 2004 | 01:57 PM
HumpinSS's Avatar
Have you checked you PR lately. When my valve spring went to **** I started getting a whole bunch of misfires on a few cylinders
Old Jan 19, 2004 | 05:46 PM
seadog's Avatar
i don't know what you mean by pr?
Old Jan 19, 2004 | 05:47 PM
seadog's Avatar
should i do the top cleaner first or check my intake gasket?
