92/92 tuning advice
So I installed a Fast 92/92, some 42# SVO Injs..
I feel confident I followed the inj scaling write up, and spread sheet correctly... but I still think my idle is off, and the air tables are not right.
from what I have read, I need to log LTFTs, adjust VE, then STFTs and adjust VE again.. Is that really all that needs to be adjusted to tune for the intake??
I am new to tuning, and I have HPTuners..
thanks in advance
you need to get your RAF re-dialed in probably, the 92mm throttle body will change those variables, my 90mm did quite a bit.
For tuning VE i disable LTFT and go off of STFT, as they respond much quicker. Or better yet if you have a wideband disable STFT as well and tune with afr/error % in hp tuners.
If your running MAF make sure you dial that in after you get your VE in line.
From there, looks like I still need to figure out the green tops, to ensure they are right.. I have compared with 2-3 different tunes, and I have the same figures they have, which could just be nothing more than all 3 of us are wrong!! But I want to be sure my pulse width, and all are correct for the svo 42#ers, is there a method to doing that?
$0.02
