Misfires in internally stock engine?
First run, I was gettin some KR in a few instances, none of them at WOT. I checked all the plug wires, and then decided to log a couple of runs in which I monitored the current and history misfires for each cylinder. I had no knock at all during these two runs, no matter how hard I tried to duplicate any conditions that might have caused it, but at and close to idle, I was experiencing misfires on several cylinders that I can't seem to track down.
I'm at 39,500 miles, with about 15k on some TR55s. I've got a new set of plugs on order and I plan on using some Top Engine cleaner at the same time to see if that clears up the problems. The most concerning aspect of this is that I've got a lovely dieseling sound at low rpms that I'm assuming is related to both the misfire and the knock.
If anyone has any advice, I'd be more than happy to accept it. If it helps, I've got all 3 EFI Live logs that I'd be happy to send out for analysis.
Thanks guys.
Has your car had any type of hesitation? or smelling of any excessive exhaust? If so, it might be your problem.
Just a guess.
Just a guess.
Even a warped brake rotor can cause uneven crank rotation and trip false misfires.
Leaking injector sucking in air, partly plugged Cat and of course running too rich
Misfires of course are not necessarily KR on efilive. What i need to find is the pid to log the Octane table so we can see where the misfires + KR are putting him between the low and high maps.
Lemme go meander over to the efilive forum and see if i can figure out what pid it was. For the record. My car throws about 10-20X more misfires at idle(specially cold). I attribute it to the poor mounts (being replaced now all poly) and the pacesucker LT/ORY which bangs everything all over the place.
Taking the crowbar and rapping the LT would throw about 1 KR on efilive. Thats how sensitive the knock sensors are. However we must not mix up Misfires and KR. Both are occurring on this car, but not under great amounts. Well i don't have another stock car to base that on...
I gather I'm going to need to go through everything with a fine toothed comb to figure this one out.
The PCM detects engine misfire by detecting variations in crankshaft deceleration between firing strokes. For accurate detection of engine misfire the PCM must distinguish between crankshaft deceleration caused by actual misfire and deceleration caused by rough road conditions.
The antilock brake system (ABS) can detect if the vehicle is on a rough road based on wheel acceleration/deceleration data supplied by the wheel speed sensors. If the ABS detects rough road above a predetermined threshold, this information is sent to the PCM via serial data. The PCM can then take the rough road into account when calculating misfire.
Even if the ABS is malfunctioning and cannot detect rough roads, the misfire diagnostic will continue to run. However, if a misfire DTC sets, this additional DTC also sets indicating that rough road data was not available during the misfire calculation due to an ABS malfunction.
Warped rotor causes uneven load on drivetrain which causes slight variation on crank which the CKS sensor picks up and trips false misfire.
ABS tripping due to dragging of brakes of one part of rotor will also cause false misfire.
Slipping belts, pully or unbalanced, anything that causes crank to not have smooth rotation can fool CKS and reason why EPA allows nameplates to lighten up the internal misfire tests in PCM but still cannot catch all false misfire conditons.
Is it possible that gutting the cats and using sims can cause the front o2's to misread the a/f (untuned car) due to the fact the o2 sensors may not have the heat from the cats/restriction? Could this cause the o2 sensors due to increase airflow and less heat to read skewed?
fool the O2s some and without tuning for that would cause problems.
Not usre how the subject was about misfires and now its mainly about knock but clearly with exhaust changes the AFR would change and can cause knock being the O2s may be reporting too rich when its really too lean.
The car was getting 12mpg!!! THAT Sucks!!!!
We put the car on the laptop and found out the O2's were the problem, new ones fixed the problem.
Purchased tuner finally!!!!
