P0327/P0332 Help
I've read all the info I can find...
http://www.hotrodlane.cc/New%20LS%20...or%20P0332.htm
Replaced front sensor and wire harness... no relief. What else can trip this code aside from the harness/sensors? Will real knock cause the codes?
PCM?
MAF?
MAP sensor?
Anything like that potentially an issue?
joecar, I did what I could without having a scan tool. I do have a friend at a performance shop who said he could datacapture on his laptop and go from there. I'll try to get that done in the next couple days.
I was also told if could be a fuel pressure issue? This is a headache I didn't need right now.
It's throwing both codes at once... and the harness I removed and the harness I put in have both checked out ok (60 bucks down the tube there).
Took the car apart again and discovered the rear knock sensor was broken..
http://tinypic.com/r/2jbcy0/7
P0332 code is gone but P0327 is still on. What are the chances I got a bad knock sensor from GM Parts Direct??
