Crank Relearn procedure....which scanners can do it???
Do you think the dealership would charge alot for a 4 second procedure?
I have a Genysis and Tech II. The Genysis says that it will do it but it won't for some reason. The Tech II will. If you were near Cincy I would do it for free for you, maybe you can make a post to see if there is someone in your area with a Tech II that will help you.
My experience is with EFILive and it seems to work as long as you pay attention to the following:
None of the following diagnostic trouble codes must be set - or the CKP learn procedure will not run:
• P0335 Crankshaft Position (CKP) Sensor A Circuit
• P0336 Crankshaft Position (CKP) Sensor A Performance
• P0341 Camshaft Position (CMP) Sensor Performance Bank 1 Sensor A
• P0342 Camshaft Position (CMP) Sensor Circuit Low Bank 1 Sensor A
• P0343 Camshaft Position (CMP) Sensor Circuit High Bank 1 Sensor A
• P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low
• P0118 Engine Coolant Temperature (ECT) Sensor Circuit High
• P1539 Air Conditioning (A/C) Clutch Feedback Circuit High Voltage
• P1546 Air Conditioning (A/C) Clutch Feedback Circuit Open
• P0705 Transmission Range (TR) Switch Circuit
• P0706 Transmission Range (TR) Switch Performance
• P1810 Transmission Fluid Pressure (TFP) Position Switch Circuit
• P1825 Internal Mode Switch-Invalid Range
-ECT must be between 150F and 220F
-RPM must be below 2400rpm before starting the procedure
-TPS must be 0%
-VSS must be 0
-Apply the parking brake
-Put in Park/Neutral
-Turn off all accessories
-Keep foot on brake
- connect scantool (click green connect button),
- goto DVT tab,
- select controller,
- click Activate,
- goto Learning subtab,
- click CASE (see next line),
- open throttle to increase RPM above 4000 within 10 seconds (see next line),
- when you hear/feel stumble/misfire immediately release throttle,
- let engine spindown to idle,
- after reaching idle, turn off engine and wait 15 seconds,
- while waiting 15 seconds, you can click Deactivate.
Also, the wind must be out of the NW at no more than 15mph
-TPS must be 0%
-VSS must be 0
-Keep foot on brake
- goto DVT tab,
- click Activate,
![Icon Razz](https://ls1tech.com/forums/images/smilies2/icon_razz.gif)
you can just turn that code off, it is just for misfire detection and wont have any effect on driveability or hp, if you have a cammed engine you probly already have the misfire tables changed or turned off
-TPS must be 0%
-VSS must be 0
-Keep foot on brake
- goto DVT tab,
- click Activate,
Also, the wind must be out of the NW at no more than 15mph![Icon Razz](https://ls1tech.com/forums/images/smilies2/icon_razz.gif)
-TPS must be 0%
-VSS must be 0
-Keep foot on brake
- goto DVT tab,
- click Activate,
The guy that tried it did not do all those things. When the rpm reached 4,000 rpm the engine shut off each time.
I'll print this out and bring it with me next time.
Thanks.......
if you arent even using the misfire tables then just turn the code off with whatever tuning software you used to tune the vehicle,, a gm tech 2 cant disable the code,, only tuning software,, hptuners, efilive, tc obd2
