Whats the purpose of PE
Many different way's to skin a cat, in the end make your actual AFR = Commanded AFR
switchpoint voltages in the appropriate airflow mode cells
to 250mV or so and see what the wideband says.
PE is the way you get into open loop fueling based on TPS,
MAP. Then it offers an enrichment (which may or may not
win the argument) based on RPM. Your EQ table, which is
now also in play, offers another based on MAP. Fat kid
wins. So you have those two (or maybe more like 1-1/2)
degrees of freedom to set up a high-load fuel map. Kinda
crappy but it's what you have to work with. Some OSes
offer additional *****. But it sure would be nice to have
a desired EQ vs MAP vs RPM response surface instead
of one-dimensional vectors more or less.
I also agree with jimmyblue that a map based multiplier or a 3d graph to slowly ramp richer mixtures in instead of running stoich and instantly hitting PE of 13.0 afr or in a boosted app's case 11.50 or richer instantly. (BE is too slow to rely on)
the PCM's model is to calculate airmass from the VE table, and then divide this by the commanded AFR (from the richer of the active AFR tables) to obtain fuelmass, and then use the IFR to calculate pulsewidth to spray this fuelmass...
so yes you could maybe trick the PCM into calculating a larger airmass and end up with the same fuelmass (by virtue of having a leaner commanded OLFA/PE)... (and some people take it further by adjusting the IFR table...)...
but (for example) this makes dialing in AFR at the track (for best ET/TS) much more difficult... getting the airmass correct allows you to very simply achieve the commanded AFR (what-you-specify-is-what-you-obtain), this will make your tuning life simpler (and the PCM is designed to help you do this).
tables, is realism.
"Intent" belongs in PE, EQ vs ECT vs MAP (aka OLFA)
and adder type tables.
Lying to get a desired result, is a bad idea in the end.
.. btw, that was funny Cal!
