High rev at park to drive shift
Old Mar 20, 2011 | 12:33 AM
Hemi2Slo's Avatar
Default High rev at park to drive shift
When I transition from park or neutral to drive my car revs to about 1500 rpms and it causes it to lunge into gear and jolt the entire car. Then when I go from drive to park it revs to nearly 2000 rpms. It does it to a certain extent going from park to reverse, but its not as bad. I'm using HP Tuners and I have adjusted everything I know to adjust and it is still doing it. There has got to be something I'm missing. Has anybody had this problem and/or know how to fix it? Thanks in advance.
Old Mar 20, 2011 | 08:23 AM
Old Geezer's Avatar
What modifications have you done?
Cam?
Old Mar 20, 2011 | 11:11 AM
Hemi2Slo's Avatar
Yeah, a hot cam and bolt ons. 85mm throttle body and LS6 in take. Car is a 98. Transmission has been built and has a shift kit and 3000 stall.
Old Mar 20, 2011 | 11:50 PM
IDRIVEAG8GT's Avatar
Check the Airflow step up patterns and if there's any on the park to drive transition, zero it out. Might wanna reduce your final drive airflow tables by 2 tenths or so too. If that doesn't help then go to your idle table and make the warm idle for P/N, the same as Drive.
Old Mar 21, 2011 | 12:06 AM
Hemi2Slo's Avatar
Those must be parameters from efi live or somethin. I've never seen those in my HP tuners. If it is HP tuners stuff, where do I find those?
Old Mar 21, 2011 | 01:29 AM
Yeah it's HPT. I need your file to browse but it should be under engine>airflow>subtab idle. Then you should be able to find your airflow tables.
Old Mar 21, 2011 | 09:13 AM
Gabbiani's Avatar
Engine, Idle, Airflow, Idle Airflow - Bet the in drive numbers are a little high here.
Old Mar 21, 2011 | 09:29 AM
Thanks Gabbiani. I couldn't remember the tables for the life of me.
Old Mar 21, 2011 | 11:33 AM
Hemi2Slo's Avatar
Ok cool. Thanks guys. I'll try it as soon as I get to my laptop.
