FAST 90 Swap Idle Issue. Speed Density Tune
So, I have been messing with installing a FAST 90mm intake manifold on my ls2 camaro for a week now. First I installed it just like FAST recommends without any rtv or anything. Once installed I fired it up and it ran, but began surging at idle.
I figured it had a leak somewhere so I pulled it back off, opened it up, and RTV'ed over the gasket from the inner manifold to the top portion of the manifold, put it back together and reinstalled it back on the car. Started right up but it still surged at idle.
It seemed to run the exact same after the RTV as it did before. So I was thinking, since it ran the same before and after the RTV, it probably wasnt leaking at all if the leak didn't at least slow down..?
This makes me think the manifold is not leaking at all and its in the tune.
So my question is.... Could upgrading from a ls1 intake with 78mm tb to a F.A.S.T. 90 with a 90mm tb cause this?
My car is Speed density tuned.
I would say yes it would confuse the PCM on a SD tune. With the extra amount of air and no maf to adust tables, that would be my guess. Im not a tuner, but im sure someone will tell more on this.
Yeah, thats what I was thinking. I havn't actually looked into the details of sd tuning, or tuning at all really, until recently because of this. But thanks for the input, hopefully others will know more
yea, you need to get that retuned.
There is alot more air moving through that 90mm TB and your idle air tables probally need some adjustment. The surging sounds like the idle air because it is trying to add or remove air to find idle, but is having a hard time because there is more flow from the 90mm TB.
Like it has been said, an SD tune assumes certain airflow and gives fueling for that.
If you change the airflow, the PCM does not know how to compensate for that...so it will still be dumping the same fueling as before. But now there is more airflow but not more fuel, so the trims and AFR are off.
