wide band commander
Old Feb 25, 2004 | 08:56 AM
XLR8VRL's Avatar
Default wide band commander
this was in Hot Rod mag last month. widebandcommander.com anyone have one yet? looks pretty cool any other options for wideband installed in the car?
Old Feb 25, 2004 | 10:28 AM
samz28's Avatar
looks great; like a innovative but with a analog gauge add-on and rpm/tps hookup.
Lets face it widebands are commodity items. Everyone should have one. Hell i got an NTK and a LSU4 based one at home for tuning purposes (vw boosted cars mostly). But they make you a disbeliever in air fuel gauges once you've seen one in action.
nitrous without a wideband imo is just plain crazy
Old Feb 25, 2004 | 11:05 AM
RICE ETR's Avatar
Turbo Addict
I've had one on order.... they are about two weeks behind on back order.
Old Feb 25, 2004 | 11:07 AM
jimmyblue's Avatar
Moderator
Very pretty, but the price hurts me just to look at.
Need to figure out the home-built control circuit....
Old Feb 25, 2004 | 11:41 AM
RICE ETR's Avatar
Turbo Addict
the dist's i talked to mentioned mid to high $400's for the kits once they get some in. I just need my sooner so i am paying a little more to get it direct
Old Feb 25, 2004 | 11:55 AM
slow's Avatar
ditto... they're nice to have
a friend has the FJO and another just got the innovative.
I will be getting one before the blower goes on.
Ryan
Old Feb 25, 2004 | 01:28 PM
66ImpalaLT1's Avatar
Does anyone know if the wideband commander calibrates or if it uses the resistor mounted on the LSU4's connector?
Old Feb 25, 2004 | 02:01 PM
samz28's Avatar
the fjo is top notch stuff. I believe one of the tuners is adding 0-5V input to datalogging, which would allow you to use the output of the better widebands to be logged in (ie efilive).
This would be cool. 0-5V is more resolute than 0-1V imo.
I find the bosch lsu sensors are not as fast reacting, but the ntk-based ones are more "impulse" sensitive to exhaust. This can make it harder to tune at idle on a ntk based one since you get alot of spiking.
The dyno's that use bosch do a helluva lot of smoothing so the actual doesn't look like a saw blade, its due to the slow sample rate and the fact you don't want to see it.
me i'd rather see it...
Old Feb 25, 2004 | 04:56 PM
Fetumpsh's Avatar
In fact 2 x 0-5V inputs, so yes one could be from a WBO2 controller output, the other maybe a boost pressure sensor, dyno output, whatever has a 0-5V (or 0V to whatever less than 5V output) could be 'blended' in with the EFILive log file
Old Feb 25, 2004 | 07:05 PM
Bink's Avatar
I have an FJO setup. I bought a new O2 sensor recently but damned if I can tell who it's made by! Who makes the FJO sensor an d how does it compare to the others??? TIA.
joel
Old Feb 25, 2004 | 07:10 PM
samz28's Avatar
last time i checked the fjo was a ntk based sensor. They may have changed, i dunno. FJO has been around for quite a while.
bosch sensors are cheap like $17-50 (wholesale to retail), the ntk's are generally $100-200 each btw
Old Feb 26, 2004 | 06:22 AM
Fetumpsh's Avatar
That's gotta make you wonder
Old Feb 26, 2004 | 06:52 AM
samz28's Avatar
well considering the millions of cars running their primary lsu wideband on the road today (IE every DBW 1.8T VAG) in the world, its probable the price is low.
The NTK was used on a hybrid lean burn car, not so many sold.
The VW Bosch sensor is the $17 dealer cost. If you feel like torching it with leaded gas, no biggie, its less than a regular narrowband sensor lol.
power in numbers. GM uses them on cadillacs too
Old Feb 26, 2004 | 07:41 PM
Fetumpsh's Avatar
$17 dollars, you can't go wrong really!!
Old Feb 26, 2004 | 10:13 PM
Drake's Avatar
Anyone have a part number on that cheap wideband baby? Might be time for a new engineering project...
Old Feb 27, 2004 | 07:08 AM
samz28's Avatar
read up at www.wbo2.com
keep in mind the sensor is useless without a closed loop controller. It's a nernst cell ion pump. It will do nothing without a cpu or analog driver to keep it "focused" on the correct ratio.
simple words: The system determines air fuel by pumping (ions) of air in, the amount it must pump in is equal to the air fuel ratio. unlike a normal o2 sensor which is fixed at stoich, this one can change its "on" point using feedback and a closed loop to control the ion pump.
so no the $17 wholesale part won't do sheot without a box to drive it.
