Knock sensor? LS2 block with LS1 computer
Can reprogramming be done with HP Tuner? That's what I have but I'm not familiar with it yet.
I'm trying to figure out if it's a reasonable recreation of the LS2 technology or if the LS1 ECM has the identical capability but just not utilized in the Camaro. I'm not interested to do the switch myself (leave that to you) but I do want to understand what is done and how it behaves after the switch.
- The broadband single wire sensor
- The flat response 2-wire sensor
Both sensors use piezo-electric crystal technology to produce and send signals to the PCM. The amplitude and frequency of this signal will vary constantly depending on the vibration level within the engine. Flat response and broadband KS signals are processed differently by the PCM. The major differences are outlined below:
- All broadband sensors use a single wire circuit. Some types of controllers will output a bias voltage on the KS signal wire. The bias voltage creates a voltage drop the PCM monitors and uses to help diagnose KS faults. The KS noise signal rides along this bias voltage, and due to the constantly fluctuating frequency and amplitude of the signal, will always be outside the bias voltage parameters. Another way to use the KS signals is for the PCM to learn the average normal noise output from the KS. The PCM uses this noise channel, and KS signal that rides along the noise channel, in much the same way as the bias voltage type does. Both systems will constantly monitor the KS system for a signal that is not present or falls within the noise channel.
- The flat response KS uses a 2-wire circuit. The KS signal rides within a noise channel which is learned and output by the PCM. This noise channel is based upon the normal noise input from the KS and is known as background noise. As engine speed and load change, the noise channel upper and lower parameters will change to accommodate the KS signal, keeping the signal within the channel. If there is knock, the signal will range outside the noise channel and the PCM will reduce spark advance until the knock is reduced. These sensors are monitored in much the same way as the broadband sensors, except that an abnormal signal will stay outside of the noise channel or will not be present.
little more on the broadband single wire sensors
The PCM uses a KS in order to detect abnormal vibration in the engine, such as detonation, or spark knocking. Mounted in the engine block, the KS produces an AC signal at all engine speeds and loads. Next, the PCM adjusts the spark timing based on the amplitude, and on the frequency of the KS signal. The PCM calculates a normal level of engine noise, also known as the noise channel, from the KS signal. The noise channel consists of an upper and lower region. A normal KS signal should vary within the noise channel as shown in the Knock Sensor Signal - Normal. A KS signal outside the noise channel, as shown in Knock Sensor Signal - Knock Present, indicates spark knock. The PCM will then adjust the spark timing to eliminate the engine knock
(1) Upper Noise Channel Region
(2) Noise Channel Average
(3) Knock Sensor Signal
(4) Lower Noise Channel Region
I've been looking around and I still can't find anybody who has been successful tuning an engine this way. Lots of examples of engine not running right and going back to LS1 knock sensor. Can you point me to some board members that made it work?
I have copied tables from a 4.3 litter, but I know the sensitivity tables are way off. I had an issue last summer with a run that was way too lean and the LS2 style knock sensors did pull timing, but not enough... Damaged 2 pistons.
Thanks!
then you have to redo ALL of the knock tables...and its not a simple or easy task... lots of trial and error...
simpler to just stay with the stock LS1 one wire style sensors.
you can use the LS6 valley cover on an LS2 block with no issues.
neither sensor really works any better or any worse if tuned correctly...
Then I go to the Knock Sensor Global Gain table and multiply the entire table by .9 at at time to increase the knock sensor sensitivity until spark knock is seen with sensible spark timing, then increase the table by 5%.
And an LS6 valley cover will not fit on a LS2 block.
Russ Kemp
My concern is that the knock sensors and harness for the LS1 are extremely close to the headers.
The LS2/3/7 knock sensors use different types of tables and might not be compatible with the express van/s10 data.
If you want to do this right you need the right approach and that is factory data with factory sensors with factory locations. Since not all 3 can be had at least factory data with the factory sensors can be used.
I doubt the racetronix conversion harness (which I have) works, since the pin to the ECU is different than the stock pins. Unless you only need to pin 2 wires, but I recall you need to repin all 4 wires (2/sensor).
I am trying this now and not having much luck currently. I bought the adapter harness from BP Automotive and have the grounds grounded to the block. Block is brand new and clean. I have the tune changed to flat response and have the sensors maxed out making them as sensitive as they can be right now. I have tried both pin locations, stock 11/51 and also 9/10 and have not gotten any response from the sensors when unfortunately I can hear audible knock from the engine at times under isolated conditions. I have a few more troubleshooting things to try to get them to read but just looking for feedback.
I have copied tables from a 4.3 litter, but I know the sensitivity tables are way off. I had an issue last summer with a run that was way too lean and the LS2 style knock sensors did pull timing, but not enough... Damaged 2 pistons. Thanks!
