Whats the normal readings?
Old Jul 10, 2011 | 09:17 AM
MillsMotorvation's Avatar
Default Whats the normal readings?
Just installed a Aeroforce, and dont know what is the normal reading should be. Like it shows TPS,MAF,MAP ...ect what should be normal settings. Car has been idling rich, MAP is 15 vac, is that low for a Z06 cam in a LQ4? I swapped this into a 1981T/A.
Old Jul 10, 2011 | 10:37 AM
SSpdDmon's Avatar
If it's MAP - yes 15 is good. Show's lots of vacuum. If it's really manifold vacuum, then it would be bad.
Manifold Vacuum @ WOT is usually close to 0.
MAP @ WOT is usually close to 100, but will vary based on weather and elevation due to the way it's calculated (barometric pressure minus manvac).
MAF will fluctuate with throttle application. Should be under 10 grams per second at idle and over 275 grams per second at WOT.
Old Jul 10, 2011 | 11:01 AM
Ok, will boost show vacum? 14/15vac is that bad. What show manifold vacum. Can you give me a idea of normal for other readings, TPS, IGN Adv, short term,long term,O2s, ect. Do i need to install a FPR other than the stock one? Car idle rich to the point of stalling out. Im add turbo soon, need it ready for a tune.
Old Jul 10, 2011 | 11:20 AM
Ok, I may have the wrong,or bad MAF, Its reading 1.22/1.39 at idle on MAF lbs/mm.
Old Jul 10, 2011 | 02:19 PM
bigairboarder44's Avatar
MAP = Manifold absolute pressure (in kPa)
TPS = Throttle position sensor
IGN ADV = Ignition advance
Short term = Short term fuel trim
Long term = long term fuel trim
O2 = Oxygen sensor reading (in mV)
MAF = Mass Air Flow
Old Jul 10, 2011 | 04:32 PM
Big air what should they read?
Old Jul 10, 2011 | 08:13 PM
Help!
Old Jul 11, 2011 | 05:38 PM
During idle and your foot isn't on the gal pedal, TPS should read zero. As you press the accelerator, MAP should increase. Like SSpdDmon said, at WOT (wide open throttle) MAP should read 100-105 kPa.
Ignition advance varies and at idle, the stock advance is anywhere between 20-30 degrees, but that also depends on if there are any modifiers present.
Short and long term fuel trims should be between -4 and 0. Sounds like yours are much lower (less than -4). O2 sensors should be between 400-700 mV, however that also depends on how rich/lean you are running.
At idle, the MAF should read <2 lb/min. Mass air flow is how much air is going into the engine so that will depend on TPS as well.
If any of that information is incorrect, someone please fix it - I'm still learning (but always will be).
Old Jul 11, 2011 | 07:39 PM
Thanks, MAF is1.20/1.39 lbs,or mm. Short term is -13/15,O2s are400-800hot,MAF is -13/15. Can smell raw gas. Do need to add
Old Jul 11, 2011 | 08:11 PM
Ok, what should Fuel Psi be at idle? My FP is 60/65lbs,thats got to be to high.
Old Jul 11, 2011 | 08:55 PM
Nope, that's right where it should be.
Old Jul 12, 2011 | 07:11 AM
At idle? So i need a tune.
Old Jul 12, 2011 | 07:21 AM
SSpdDmon's Avatar
If it's 60...it's OK. 65 is a touch high. Do you have an adjustable fuel pressure regulator since it's an 81? LSx motors usually are set to run @ 58psi.
Has anyone tried to tune it before?
Old Jul 12, 2011 | 07:27 AM
Sent PCM to have VAT removed, thats all. It idles rough, and FP bounce between 60/65. Has stock FP reg.
Old Jul 12, 2011 | 07:31 AM
Adjustable FPreg is on the way. Has the truck intake.
Old Jul 12, 2011 | 07:54 AM
SSpdDmon's Avatar
I'd also borrow/rent a FP guage to make sure yours is reading correctly.
As for needing a tune, I'd recommend getting one (or learning how to do it yourself) anytime something is changed. Since you have a virtually stock tune with an LS6 cam, your fueling is going to be off and so is your timing. You're likely within the parameters of the PCMs ability to adjust. BUT...things like fueling at WOT are a guess for the PCM as it doesn't have an accurate feedback loop to reference. It can only assume that any fueling requirements (%) added at part throttle are necessary at WOT. And timing....it will pull timing if it detects knock. But, timing will eventually creep back up to where it was only to repeat the cycle.
Old Jul 13, 2011 | 08:39 AM
OK thanks.
Old Jul 13, 2011 | 08:44 AM
I have a FP gauge on the rail.
Old Aug 7, 2011 | 07:18 PM
Got the FPR on the car, and it run's great, but had to drop FP to about 48lbs for it not to be rich!
