Injector help, 400RWHP Bolt-on LS6
Old Jan 3, 2012 | 01:25 PM
niphilli's Avatar
Default Injector help, 400RWHP Bolt-on LS6
Hello All,
I am thinking of doing some bolt-on modifications to a 2003 Z06 and have some questions about injector duity cycle. The target is 400RWHP with a very conservative tune.
What injector would be reccomended for a safe setup? Are the stock units up to the task?
Please keep in mind that I want this to be conservative, the car is babied but I want it to be built so that I could take it to a roadcourse and have no problems. I want stock reliability out of a 400RWHP setup, or I will just leave it stock. Its a better car than I am a driver anyway.
Thanks,
-Nick
Old Jan 3, 2012 | 01:55 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
Originally Posted by niphilli
Hello All,
Thanks,
-Nick
stock injectors will be fine...
Old Jan 3, 2012 | 01:59 PM
wait4me's Avatar
Stock or if you are worried, get a set of GTP white 36lb ones. The tables are available for them.
Old Jan 3, 2012 | 05:30 PM
niphilli's Avatar
Thanks Wait4Me~ I was concerned that 400whp was on the limit of the duity cycle for our stock injectors and would not want to risk that in a roadcourse environment. How difficult is it to tune in the new injectors? Nothing scares me more than some hack screwing up the tune in the car just so I could get 50 more horsepower out a car that is already very capable.
I have played the tuning game with a respected vendor (previous car) before and was not pleased with the outcome at all.
Thanks!
-Nick
Old Jan 3, 2012 | 06:42 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
Thanks!
-Nick
the data is all available for that injector, load the data, data log the fuel trims, they should real close, edit from there if need be...
Old Jan 3, 2012 | 06:48 PM
Carter01's Avatar
I have a cam only 99 ls1 with 03 vette injectors and I make roughly 400rwhp with them. They usually run around 88% at wot.
Old Jan 4, 2012 | 10:00 AM
niphilli's Avatar
Thanks All!
Old Jan 4, 2012 | 11:05 AM
99french's Avatar
ford red tops are what i run in my car. i do need to check duty cycle but they are a 36lb injector on gm fuel pressure
