fast- wideband o2 set up dont make sense to me.-->>>
Please help me figure this out. With the fast system's wide band o2 option. ..They give you 1 wideband sensor to mount into one of your headers. And you dont use the stock o2's any more. So in my little mind im picturing this.... Lets say you mount it on your driver side header. And you tune her all up and everything is fine. Then all a sudden you have an intake leak on the side of the wide band o2. All of a sudden the car computer (now the fast system ) says 0 **** we are running very rich. So now it starts pulling fuel from the motor...Will it cause it to run dangerously lean on the opposit side.. Please correct me if im wrong.
I thought the same thing when I installed my wideband sensor (not a FAST System). Think it through...we tuned carburated cars for years with zero sensor input from either side. At least with the FAST your only at risk for a lean catastrophic incident - not very likely.FWIW.
joel
joel
joel
joel
LS1Tech Co-Founder
Remember once you have a FAST system you are tuning in speed density and no longer need factory 02 sensors.
I have my FAST w/b plugged into the driver's side 02 bung in my headers. The FAST, if you have the correction feature enabled, will make changes to your A/F to keep your A/F at the targeted number. let's say at WOT your target A/F is 11:1. Well the FAST will add fuel if you run lean for any reason. It will add or subtract up to 25% fuel.
My only concern is that the computer (fast) is not going to know whats going on in the other bank. So if the side you dont have the wideband in goes lean. How will the computer know. So lets say you are driving around like that and then the side you have the wide band in goes a little rich. So the computer is going to pull fuel from both sides and possible destroy the motor. I know that it is unlikey. But very possible.
To correct this i plan on swaping the wideband from side to side Every week or 2. That way i should be able to catch it if one side starts to run leaner or richer due to gasket failure.
Are you happy with your wideband. DID it make tunning the car any easier. Thanks for your help
joel
LS1Tech Co-Founder
Maybe the FAST sequential can tune for each side I have no idea.
I see your paint about each side but I don't know the answer.
I'm making 746rwhp with mine and won't be switching.
If any one is intrested , we are trying to get a gp on the fast systems. Only need 5 more people to make it happen. Check it out
