need a tune for my stall.
If your engine is tuned well, then you can just tune the transmission for the stall change and it should be cheaper obviously as the tuner is only doing part of the work.
Something as easy as a tc change shouldnt be a big deal though. It is only about 30 tables to be fixed.
TCC pressure tables/ "depending on clutch type of coarse"
Some TPS tables.
Some missfire tables,
some shift points and tcc lock up points,
Sometimes timing.
Sometimes line pressures.
Delete a few slipping codes.
Change some TRANSMISSION DTC ACTION peramters.
