91 to 101 octane do you have to change timing?
I have a 2000 ta mods are in signature thinking of using good fuel , don't under stand timimg need more or less or leave it alone ? 91 pump to VP 101
Increase timing. The higher the octane the more "aggressive" the tune can be.
Best bet would be to get on a dyno and see what kind of timing your car likes, not just blindly throw timing at it with some racing fuel and that's it.
101 octane is overkill, unless you are spraying nitrous or going forced induction, you'll only waste your money with 101 or higher gas.
Higher octane fuel won't do you anything unless you can burn it. The higher the octane of the fuel, the slower it burns. Basically, you want to run the lowest octane fuel you can get away with. If your cars timing is optimized for premium unleaded, it can compensate somewhat for lower octane gas (a little less performance). Now if you had high compression, advanced timing, lots of boost or nitrous you may benefit from running higher octane fuel. In the end don't waste your money if you don't have to. Your system needs to be setup to work with each other, timing, compression, etc.
I was told by a vp dealer at the track I could get a couple tenths to going to his 101 or 109 but my car runs good for no more than I have done to it , being a bolt on car
Optimum timing is when maximum cylinder pressure coincides with a particular piston/crank position... higher octane fuel burns a little slower so you can advance the ignition event... the problem comes (as was alluded to above) when you movethe maximum pressure position away from optimum (i.e. you lose "leverage").
