anyone else fed up with HP tuners beta versions?
At least yours is working, Im so lost I cant even install mine right! When I think I got the drivers installed, and hook to the car to scan it says that Im not connected, and to check the cable!!! Im toally lost, did Insatll drivers wrong for it to say im disconnected? The green light come on if I connect to the OBII, and it comes on if I hook to the laptop! My AeroForce gauge reads from the OBII plug just fine, so tell me what I may have done wrong? Its been 2 weeks just rying to get the thing where I can use it
. Maybe Im just to old school. Help!!!!!
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
FWIW...
I went back to the 2.22 stable build because of bugs in the Beta's(and I'm moderator, and helped with the original scanner design and how histograms worked)
I dont mind testing when theres a new big change...but right now the big changes all work just fine and its little bugs that need to be sorted out...
My biggest issue is problems with how RTT works in the Beta...
I personally think the changes they made to it suck donkey *****.
it now loads slow, and writes slow.
took almost 2 minutes for it to fully load a 3 bar OS VE table...and just as long to write a blanket +10% to it.
It was faster for me to shut off the car, write the calibration, and restart the car than it was to just load the table in RTT to even begin to make changes.
the 2.22 table loads in 15 seconds, and writes in about 20 seconds for the entire table
Beta updates are for beta testers only, if you have it is because you asked for it for testing purposes.
Beta tester = somebody who understands what "beta" means
Everybody else must use the latest stable release (2.22) which has everything working good, including analog inputs with standalone datalogging.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Tuning is a real wake up call for those who know nothing about it and go out and buy the program (like I did). Wow, I've been reading for months (in my free time) and am just barely comfortable making basic VE table changes. It's a lot to take in that's for sure. It won't be handed to you on a silver platter so man up.
I upgraded from my standard interface to the pro for the standalone datalogging as much as the analog inputs. Apparently my new pro box is new enough that it only works with the beta software (there was no connecting to the vehicle in any way with 2.22), so no standalone for me. I would be datalogging on the way to and from home work every day if I could, just fine-tuning the new cam tune right now.
The kicker is, I had to request the beta software after the upgrade, even though it was the only software that would work with the new box. So I sat there for an hour trying to figure out why it wouldn't connect... nobody told me.
I don't have any problem with the Beta and as for the HPT forum, I see lots of guys asking the same question over and over. If they would simply do a search they would find the answer and I'm sure the guys that hang out there get tired of saying the same thing over and over.
I try to do research and find the answer myself and only then do I post up a question. I have even posted up threads where I solved my own problems and hoping this might help others in the future. In the past I have posted up questions and received inbox messages where someone offered to help me if I paid them. I would rather figure it out myself than pay for someone to help like that!
I wonder if the forum even has mods that watch over it.
beta has been decently fine with me,seems like it has a few bugs to it but there not a big issue.i see both side of what people are saying about there forum,but you also cant expect them to basiclly tune your car.the biggest issue for me learning how to tune was finding injector data.but between hp tuner forum here and a google search you can figure out alot.my setup is pretty simple just a rearmount lq4 camaro but i have it runnig great on my own with a 2bar os,to me its more of a sense of accomplishment to do it on your own.glad i bought the software.
From what I've seen with the internal EFILive virtual VE is that it's not as accurate as the external Bluecat tool that we use on HPTuners. However it would be nice if HPT would implement that tool into the software for those applications, however I sense the reason it's not being implemented right off is because it would kill the sale of HPT's custom OS's that give you a true VE table.
Either way ya go you gain some and lose some. I prefer HPTuners just due to the streamline of the software but the same result can be accomplished with EFILive too.
