what can cause a lean condition besides tune
Old Jun 16, 2012 | 01:05 PM
hodge9386's Avatar
Default what can cause a lean condition besides tune
so i just installed my new wideband, tr55 plugs and msd wires and went for a lil test drive and my afr at part throttle is about 14.7-15.0 right where it should be but my wot afr is 14.3ish. it seemed like it didnt even change or maybe the pcm is going into closed loop idk. can somebody help me out here.
here is a vid i made showing what the readings are
Old Jun 16, 2012 | 01:47 PM
edcmat-l1's Avatar
Could be many different things. Need a data log to properly diagnose it.
Old Jun 16, 2012 | 03:27 PM
crainholio's Avatar
Post a scan of your RPM and LTFTs, and paste your PE vs. RPM table.
Old Jun 16, 2012 | 03:38 PM
hodge9386's Avatar
i dont have hpt or anything to scan with.
Old Jun 16, 2012 | 07:30 PM
crainholio's Avatar
No problem I'll just magic them over Teh Intarwebz and fix it...
Old Jun 17, 2012 | 04:16 PM
jack27's Avatar
probably tuning issue if its still on 14.7
even if you have small injectors or small fuel pump ,, it should jump to Rich then lean up
so i guess its a Tuning issue
unless you an issue with your Wideband
Old Jun 17, 2012 | 07:05 PM
bayer-z28's Avatar
Wondering if you're not hitting WOT completely. It seems like it's still correcting to run at stoich (normal for anything other than WOT.)
I have my car set to run at stoich at anything other than WOT once it's warmed up. But with PE on WOT, it goes to 12.5. Cheap and easy first, check your TPS and TB to see if you're going to full WOT. If your PCM doesn't see 100% throttle, it won't go into enrichment.
I notice you said "full bolt ons." Stock TB? LS1 or LS6 intake? Bump stop mod done to the TB? If not, there's your problem.
http://www.installuniversity.com/ls1...-stop-mod.html
Old Jun 17, 2012 | 07:41 PM
Old Geezer's Avatar
Talking Worx for me!!
What he said^^^^^^^^^^
I'm amazed at how many folks want to work on these cars, yet have not even the basic tools....
To the OP... Take it to someone that has the tools to find the problem[s].
Old Jun 17, 2012 | 08:24 PM
edcmat-l1's Avatar
Times a bazillion.
Old Jun 17, 2012 | 11:17 PM
minytrker's Avatar
Everyone always wants to blame the tune first. Its not doing anything my first guess is something failed, doubt someone tuned it for 14.7 at WOT. I would check the MAF first, but without any data log or any kind of scanning capability its just all guessing.
EDIT: After reading more posts...I agree its probably the tune.
Old Jun 17, 2012 | 11:22 PM
hodge9386's Avatar
to the guys bitchin cause i dont have hpt **** you. if i had hpt i wouldnt need to ask this question i could look at it an tell myself. iv built my car from the ground up an have all the tools and no how to completely tare my car apart an put it back together, i know this because iv tore a f-body apart and built one of the nicest cars on this forum. i was just wondering if there is any sensors i could check (i can get things like a maf from my buddys car to see if it still reads the same)out and see if there bad until i can get up with my buddy that has hpt.
to the guys actually trying to help me thank you.
bayer- it has a ls6 intake with a stock tb that i ported and polished a lil bit. i did not get anywhere close to the blade all i really did is take the edges out of it an smooth it out a lil and then polish it. i did not do the bump stop mod.
i think it is a problem with the tune myself. when i switched over to a t-56 i had my buddy flash my pcm over to a m6 os, but he just used a tune from his car when he was bolt ons like me and then we did a wot run and was reading 13.6 aft through the narrow bands with no knock or anything so we called it good and never thought about it until i noticed i was getting terrible gas mileage (around 270 a tank or 18mpg) and i drive mostly highway 20 miles one way to work. so i did all the normal things to fix the bad gas millage issue, replace fuel filter, plugs, clean maf, tb, and ran some sea foam threw it and nothing helped so i bought the wideband and new tr55's and msd wires, and this is where we sit now until i can meet up with my buddy and look at what the car is doing.
if i was getting 14.3 afr at wot this whole time shouldn't i have blown im engine by now, i go wot at least once every day.
Old Jun 17, 2012 | 11:40 PM
therealcreeper's Avatar
this is the PCM Diagnostic and Tuning section, hard to diagnose PCM Diagnostics and Tuning without proper information..but anyway
was your friends' car the same year? 2000 for instance got smaller injectors so if you flashed a 2002 tune that'll be way off, etc.
Old Jun 17, 2012 | 11:52 PM
minytrker's Avatar
First problem is just loading your buddy's tune and not actually getting your car tuned. If it was that easy then there would be no point in a custom tune. Without tuning software to data log or a advanced scan tool you will just be guessing and parts swapping. There are to many variables to know if your engine would have blown being that lean all the time. It probably is that lean being you haven't actually tuned your car.
Old Jun 18, 2012 | 05:31 AM
BLK02WS6's Avatar
13.6 through the narrow bands - how exactly do you know that? and you call that good... The car needs to be scanned/logged in order to properly diagnose any problems...
Old Jun 18, 2012 | 06:39 AM
edcmat-l1's Avatar
Yup..
Old Jun 18, 2012 | 07:32 AM
Old Geezer's Avatar
"to the guys bitchin cause i dont have hpt **** you. "..........How about you shove your problems up your ***...
Old Jun 18, 2012 | 03:10 PM
crainholio's Avatar
I don't see anybody specifying HPT except you. Scanning (not tuning necessarily) is a basic requirement of diagnosing a computer-controlled engine, so if you're going to work on your car yourself it's a good investment.
Maybe shop around for a used AutoTap or old EFILive scan-only kit for cheap, it will pay for itself in shop labor avoided.
edit: or for $50 or so get a universal scanner cable like these: http://www.scantool.net/
So with all your massive "...I no how to completely tare my car apart an put it back together..." skill, you can't diagnose it sitting in front of you...but you think people here can do so? Reality check dude.
It's possible that your narrowband sensor(s) feeding the gauge are simply reporting errors, because they are only built to switch at stoich. You need a wideband O2 sensor if you want accurate air:fuel ratio data.
Old Jun 18, 2012 | 04:12 PM
hodge9386's Avatar
i have a innovate wideband, that is what the video is of. the thing about the car not going into closed loop makes since but i will have to wait and see till i can get my buddys hpt. i was just looking for some feed back on what sensors can be causing the issue so i can start looking into it in the mean time.
Old Jun 18, 2012 | 04:36 PM
MUSTANGBRKR02's Avatar
Well the tune is a stock M6 tune from a 2000 car so I doubt that the tune is off. I turned off basic codes, speed limiter, fans, fuel cutoff and that is pretty much it. The car will be looked at hopefully this weekend as I live a hour away and have been working on my car everyday to finish it along with another car that I am building.
Old Jun 18, 2012 | 04:53 PM
hodge9386's Avatar
thanks bill, just so you know im not blaming this on you, i never asked you to actually tune the car, just to swap it over to a m6 so it would run right. thanks for helping me out.
