Overheating--poor (rich) tune?
I don't drive the car more then just around the block because of the issue, so it stays under 2500 rpm the whole time. I know a lean tune can make a car run hot, can a rich tune do it as well?
I have the fans both coming on at 190*, and never had any problem until this new engine and cam. The cam is 23x-23x on 115 LSA, forged 370 with LS9 headgaskets and 317 heads.
And when do you see fueling that rich? Part throttle or full?
I'm not 100% percent sure how accurate my LC1 is, it's got about 4000 miles on it and I recalibrated it when I put the new motor in around 300 miles ago.
Car hasn't been WOT since I put the new bottom end in, all part throttle. I havn't been WOT or felt boost in 2+ years
That's what I'm most afraid of, because I'm not taking the motor apart again. This is actaully the 2nd pair of LS9 headgaskets I've put on in the 300 miles I've put on the new motor, but it was running hot with the last set too. I'm 99.9% sure they are on the right way, the LS9's say "FRONT"(towards waterpump), right?
I had a lifter turn sideways in the lifter tray last year when breaking the engine in, and wiped a cam lobe so I just put this thing back together at the beginning of this summer. It's been one problem after another since I put the new engine in, I've worked through them all but this one is driving me nuts and if I don't get if figured out by the end of this year I'm putting the car back to stock, selling the parts and getting a C6Z.
Thanks for all your help everyone, I was hoping to hear a rich tune could cause it, but I'll keep my efforts focused on the cooling system.
