Chasing My Tail....is my desired airflow suppose to be at 0?
ive been having issues with this car every since i put it together with no help from the person i paid to tune it...i cant even pull the car out of the garage the way it is.i added a few pids to the scan and noticed my dynamic airflow to float around 29ish while my desired is around 0..is that right? im having issues with high fuel trims,the car has hanging rev's and it wont idle below 1300rpm.i have zero vacuum leaks.resealed everything to be sure,even bought a smoke kit to check for leaks....what gives....2000 trans am...i have more logs but this one is for starters
Maybe you should build a twin turbo lsx 454 then ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Seriously though give it sometime. There are a lot of smart people on here. However if you bitch no one has responded to your thread when it's still on the first page it might make people not want to help.
If I knew anything about tuning I would help you out. But I don't.
if u knew what ive been thru with this car and how much money i feel like i wasted you would understand the point im at now...the local shops around here suck.so i have to resort to the "intranetz"........
I understand somewhat. After my H/C/I/E swap nothing seemed to go right. I hated the car. Finally got everything lined out except the tune. I think I'm going to bite the bullet and learn how to do it myself. If its get screwed up atleast it will be by me and not someone else I paid.
You will get it lined out man.
In vcm controls I can play with the iac steps,itll only idle higher,wont go lower.
This is a frost tune.abd yes he gives 90 day free updates but he only can be reacehed by email and he flat out doesnt respond to them but he gets your money quick.i got emails from 4 months ago that I still havent got a reply for.when u call efi performance the shop he tunes at u can leave your number and wont get a call back...never again
The IAC may need to be reset as well. Sometimes they fudge up and end up halfway open with an IAC count of 0 however without seeing the car it's hard to tell. One way to find out though is to get the car running with the intake tube off the car and cover the IAC port up with your finger to see if it is sucking anything with the IAC at 0. It will always suck a little but shouldn't be a large volume of air. The only other thing I could see it being from the email and phone convo's with you is the injector o-rings leaking air around them. The fueling is definitely way off as well but it's not going to run right until it has control of idle.
THAT CHEAP AS* GODSPEED THROTTLE BODY LOL!!!!!!!!!!!
the nick williams 102 came in today,which i may add is a very nice piece! got it installed an hell i couldnt get the car to idle it was sealed up so good.played around with the idle screw and tps and got it to somewhat hold an idle now.fought that godspeed for dang near 3 weeks now.pulled the intake multiple times...smh.now i can move on to fixing these high fuel trims.heres a log now with the new tb.about 4 minutes into the log is when i finally got it to hold an idle.but suddenly at 5:30 into the log the car stopped trimming altogether...what happend?
