Predator
Old Mar 20, 2013 | 03:47 PM
slow ride 02's Avatar
Default Predator
I have one of these hand tuners. But now I have custom tune. Is there anything intresting I can use it for, besides a code reader?
Old Mar 21, 2013 | 08:48 AM
sreve's Avatar
They have some data logging software you can DL on their site
Smokin fast using the Predator as a passthru.
Old Mar 21, 2013 | 11:50 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
if the tool is unlocked, you could use the modify stock tune option to edit the existing tune for spark, fuel, idle speed changes, etc.
As mentioned, it will datalog and read/clear codes as well.
Thanks
Old Mar 21, 2013 | 12:29 PM
Thanks
Mike,
How can I tell if its unlocked?
Old Mar 22, 2013 | 08:10 AM
LS1Tech Sponsor
did you return the car to stock before you had the custom tune done?
Thanks
Old Mar 22, 2013 | 10:02 AM
Thanks
Yes, I did.
Old Mar 22, 2013 | 04:48 PM
06MonteSS's Avatar
LS1Tech Sponsor
then as long as the predator is on revision 2.xx or 9rxx, it will be unlocked...
if it's an old one on a 1.xx revision, there's no unlocking it...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Mar 25, 2013 | 12:10 PM
Where do I find this info?
Old Mar 27, 2013 | 08:13 PM
LS1Tech Sponsor
Top line of the main menu.
Old Mar 31, 2013 | 06:42 PM
chm2001z's Avatar
can you adjust the speedometer with it still?
Old Apr 2, 2013 | 02:40 PM
Okay Mike,
Predator 1.03
MFG Date 09/02
Serial no 105575
Tool ID 54F4D0E1DA737268E
What can I do with this $400.00 paper weight?
Old Apr 3, 2013 | 06:14 PM
Mike?
Old Apr 4, 2013 | 01:01 PM
Originally Posted by slow ride 02
Okay Mike,
Predator 1.03
MFG Date 09/02
Serial no 105575
Mike, are you out there?
Old Apr 4, 2013 | 09:26 PM
06MonteSS's Avatar
LS1Tech Sponsor
revision 1.03...
olllllllld....
as I mentioned in a previous post, if it's an old one on a 1.xx revision, there's no unlocking it...
so no, you can't use it to tune or change anything....
__________________
Old Apr 5, 2013 | 06:15 AM
LS1Tech Sponsor
Yeah, thats as old as they get. It should still work since the vin is the same but i would not be comfortable recommending it without sending it in for our $99 hardware upgrade
Old Apr 5, 2013 | 03:14 PM
I still dont understand what I can do with it? I have a custom tune right now. Are you saying that if I upgrade the hardware, that I can change things on my custom tune? Or are you saying that I can replace my custom tune with it?
Old Apr 6, 2013 | 07:09 PM
LS1Tech Sponsor
the Predators offer end user adjustments such as spark and Fuel adjustments at wot, Rev and speed limit adjustment and more.
The tool you have is older and offers less adjustments. If you sent it in, you could use it to modify the existing tune.
Thanks
