WTF is up with this POS. Need HELP with P0102.
Two weeks ago I put some Grot's on. I didnt have anything to put after them so I drove home (2 miles) open header without the front o2's plugged in. I start having the exact same problem with the p0102. I figured it was just because the front o2's werent plugged in. Got the X pipe on there, plugged in the o2's, reset the pcm, still not fixed. Start doing research and found that the most popular cause was the engine sensor fuse being blown. Nope not blown. Ok, found one thread where the guy hasnt ever replaced his fuel filter, nope not it. Replaced maf again , nope not even 3 made a difference. Checked voltage to maf...5v, nope not it. Then I spin a rod bearing and put a new motor in, heads, cam, of course this has no effect.
I am getting pissed because this car is about to haul some serious nuts but I cant tell because of this stupid maf problem. Somethings worth noting. When I swap between maf's I can go drive around for 20 minutes and it hauls nuts and I actually get a maf reading from atap. If I park the car and go back an hour later it starts messing up immediately. The only thing I havent done is run new wire to the maf and replace the pcm. Another other suggestions? Sorry so long.
a 5V pullup load, resistive. Both need to be there.
If you have a DMM with frequency reading then
you should see about 2500Hz off a live MAF at idle.
I have replaced the MAF, checked the wiring, pulled and inspected every single fuse in the car, checked for leaks after the MAF, I am getting 12 volts for supply and 5 volts for the pullup, and and I just can't figure out what the problem is. Whatever it is is causes my car to bog when accelerating and run like crap. It idles decent, and is only present under load acceleration. At idle I can rev it and it revs fine. On the Tech II one of the readings for the MAF fails everytime it bogs during acceleration. And passes again immediately afterwards.
This all started last Friday after I spend 1hr and 45 minutes in traffic. On my last stretch home it started acting up and it is driving me NUTS!!!!!!!!!!!!! I have been wanting to hit the damn track but can't do anything until this is finished.
If anyone has any more suggestions on what I can check out to fix this it would be greatly appreciated!!!!!!!!!!
