all i want to do is log my wb
ive tried to log my wb. its a aem ugeo and i have it on the egr wire. i turned on the egr in the pcm. i created a config on the table
name. air fuel rairo
abbrv. afr
senor. egr position
units. afr
function. [PID.2810]/.5+10
when i hook up to the pcm and start logging it says its unsupported parameter
attached a log from this morning
abbrv. afr
senor. egr position
units. afr
Well i got arf to work thanks all.
had to change pid to 2811 and also do the egr postion in v
Ill have to wait for my trans to get back so i can start it and the voltage .
now i have a 3 bar map sensor and i have it converted to read psi. Is there a way to get it to read only boost the function i have for it now is pid.2334-101/101/14.7. at vaccume it reads -psi but i rather just see boost on the chart.
__________________
__________________
