switched from OLSD to OLMAF only to have the same problem
Things I've checked..
air is off
Car is indeed running maf only from 200rpm up.
02s are off. Temps set to 284 and disabled fuel trims
This car has never run how i wanted it to.
Pretty much stuck/lost at this point lol
I also want to fine tune the BRAF table, but i cannot do a cold start on the car, i have to hold the gas pedal down. would the russ k idle config help me any?
BRAF needs to be right, as does the start up airflow, rinse & repeat.
I'm guessing you are poking with stick & turning ***** not really understanding what the tables do & how they are going interact. As an example, why would you change the o2 switch points when you are in OL?
My suggestion would be go back to the stock file with correct injector data if you have changed them. Then start with basic's, start up airflow, rough in the BRAF, maybe increase the idle speed to stabilize. You don't have to leave the driveway! The guide is good starting point. Get it to start & idle properly
Then we can get back to the original post.
I know what the fueling tables do. Its the idle tables that I know next to nothing about. I got the iac counts to mid 60s and the car felt like it wanted to start this morning so I must be getting closeIll look for a stock file so I can do the write up steps
