TCM delete, TH400 swap in C6
Old Aug 5, 2013 | 07:14 AM
camaroandreas's Avatar
Default TCM delete, TH400 swap in C6
Hi,
We have a car with a TH400 swap in a C6 -06 aut and i need help to get it ready for the dyno.
It won´t rev over 3000 rpm. Customer has the TCM connected to get the Engine to start. What do i need to do to make it work as a manual car?
Remove TCM and mount a jumper Cable? Resistors?
I have a manual tune file i can write, but it´s not possible when it finds the tcm.
Regards,
Old Aug 5, 2013 | 07:51 AM
Ed Wright's Avatar
9-Second Club
If you have Tunercat you just select ECM when you program it. You can choose ECM, TCM, or both. I just did a blown 427" 2012 Camaro that was originally an A6 car, with a T400. If your using hpt you may be able to just unplug the TCM to get it to go. Never tried that. You may discover new lights on the dash. :-)
Old Aug 5, 2013 | 09:21 AM
I have hptuners. If you unplug the tcm it will not start or turn over..
Old Aug 5, 2013 | 09:39 AM
Ed Wright's Avatar
9-Second Club
I understand that , but it also won't even let you reflash the ECM?
Old Aug 5, 2013 | 09:59 AM
Exactly
Old Aug 5, 2013 | 10:31 AM
Ed Wright's Avatar
9-Second Club
Exactly
If you can't find somebody to flash the ECM with a manual Trans cal, you may have to send the ECM to a tuner that can flash it on the bench for you.
Old Aug 5, 2013 | 01:29 PM
fieroguru's Avatar
I kept the TCM when I went manual (2007 LS4 with E67). It has resistors for the shift solenoids, TCC and fluid temp, and the 4 wires from the range switch hard wired for D4 all the time, also wired up an actual pressure solenoid. It would still show a couple of codes (ISS sensor & not in P/N at start), but then I had a guy with TunerCat disable every TCM code (HP Tuners didn't have access to them).
Runs/drives DTC free now and I can flash it with HP Tuners. I have a spread sheet with exatly what I did to keep the T42 TCM wired up if that would help.
Old Aug 5, 2013 | 01:50 PM
LSX Power Tuning's Avatar
We do them all the time for engine swaps in old cars. You need to flash the ECM to a manual and it will not look for the TCM but you will need a speed sensor. Thats how we have done the engine swap cars atleast. It may be a little different with a standalone harness vs in actual factory car.
Old Aug 6, 2013 | 01:57 PM
I have flashed the ECU with a manual file. How do i fix the clutch switch the easiest way? I want to bypass it.
Old Aug 6, 2013 | 04:12 PM
In EFI Live I can turn off the clutch switch in the ecm but I havent tried it in an actual factory car, all have been standalone harnesses.
Old Aug 6, 2013 | 04:26 PM
I hope i can do that with hptuners, will check tomorrow.
