Using the GM flex fuel sensor on an Fbody
Old Sep 1, 2014 | 02:22 PM
  #81
Sarg's Avatar
I may have missed it. These 2005 Savana pcms, will they work with the 2000ish red and blue connectors? Is it necessary to repin the harness or anything?
Old Sep 2, 2014 | 05:56 AM
  #82
maroonls1z's Avatar
Well just so everyone knows zeitronix make an ECA that has the same output as a mg sensor for cheap and comes with a display that list E% as well. I may try to tee the output into my pcm and see if I can make it all work
Old Sep 2, 2014 | 06:59 PM
  #83
bigmandengo's Avatar
There's some good info on that topic here..
http://lt1swap.com/cable_conversion.htm
Old Sep 13, 2014 | 10:54 AM
  #84
maroonls1z's Avatar
So I am very new to the tuning, I have the 411 pcm in my fbody and I already have a inline ethanol content analyzer hooked up. If I wire it into the right pin in my pcm and upload the OS from a Tahoe/suburban with hp tuner could I switch everything to get full functionality without having to relpin anything else? I'm still DBC and I do have a/c but only use a 1bar MAP
Old Sep 13, 2014 | 01:25 PM
  #85
I don't have experience with that OS and ECM as far as flex fuel goes but I don't see why it wouldn't work. The only potential issue I see is A/C but hptuners has the ability to switch "A/C type" now so it just might work.
Old Sep 13, 2014 | 05:58 PM
  #86
maroonls1z's Avatar
Well I can't find a pinout of a flex fuel 411, and if the a/c from a truck uses multiple sensors I guess I don't know how I would pin things
Old Sep 13, 2014 | 09:31 PM
  #87
aknovaman's Avatar
Pin 56
Old Sep 14, 2014 | 06:06 AM
  #88
maroonls1z's Avatar
You mean blue 56? What I'm going to try is pinning the sensor, loading the OS and switching the ac to analog(which I understand to be the f-body setting). That being said I assume the pcm would expect the signals the way the a/c is already wired and I would not have to re-pin?
Old Sep 14, 2014 | 01:05 PM
  #89
Mike454SS's Avatar
The OS cannot change the pinout of the PCM. There are unused pins in some applications that are used in others...use the same pinout, add the flex fuel sensor to the same pin, and setup the AC settings in the OS correctly to match the old OS.
Old Sep 14, 2014 | 02:28 PM
  #90
maroonls1z's Avatar
Thanks, this is going to be awesome
Old Sep 15, 2014 | 05:15 PM
  #91
LSxPwrDZ's Avatar
Deleted post due to wrong information.
Old Sep 15, 2014 | 09:05 PM
  #92
Mike454SS's Avatar
Originally Posted by LSxPwrDZ
The easiest way to do this on a Fbody is to use a P59 (blue/green) PCM and flash a 2004 GTO OS to it. There are a few pins that have to be swapped and some codes that need turned off in the GTO PCM to make everything work correctly but I have done this on a few setups now with success.
Flex fuel pin is blue connector 56 on the P59 controllers. The P01 controllers (blue/red) is on blue pin 71. There is only one operating system in 2002 on a v8 controller that had flex enabled and had the code to operate it. Unfortunately that operating system has no upgrades for 2-3bar etc so you are stuck using the OEM tune to dial things in. This is why the P59 PCM swap is ideal to make this all work. You need to make sure the P59 controller you purchase has IAC drivers built in. Most all of your express van and V6 PCM's will have the necessary drivers to operate a cable throttle correctly.
The 2002 OS that supports it also has a 2 bar enhanced OS from HPTuners, but no 3 bar.
Old Sep 17, 2014 | 06:53 PM
  #93
greasess's Avatar
So for those of us who use EFI Live, is there a 3 bar os like COS3 or 5 for the p59 ecm? I really hope so!
Old Sep 18, 2014 | 09:24 AM
  #94
Airpump_Logic_907's Avatar
Originally Posted by 2xLS1
Yes you can. Some people just need the correct vehicle VIN in the PCM for emission testing in their state. Both EfiLive and Tunercat OBD2 don't care about valid VINS for different OS. It's just HP Tuners that requires it for the way they do their PCM licensing.
So is there any way to do this while remaining emissions legal? Would the VIN need to match in order to pass normal emissions testing?
Old Sep 19, 2014 | 12:11 PM
  #95
Agent_Orange_Shuvel's Avatar
Yes, OS 12579405 has COS3 available and is for a p59 ecm.
Old Sep 20, 2014 | 09:15 AM
  #96
Ryans99ls1's Avatar
This is perfect, and exactly what i was going to do. Motor is coming out now though, so itll be awhile.
Thanks for the info! If you get time, you should seriously do a writeup, it'll spread like wildfire man
Old Oct 4, 2014 | 02:58 PM
  #97
Pulse_GTO's Avatar
What table in HP Tuners controls the rate in which the timing is added as the alcohol percentage increases?
Old Oct 6, 2014 | 02:59 PM
  #98
Mike454SS's Avatar
I don't believe there's a rate. I believe the Flex Fuel modifier table is multiplied by the measured alcohol percentage, and then added to the main spark advance table. The % doesn't change much/often...should only change with a new tank of fuel, so I don't see any need for a rate of change control either...just apply the correction as the % changes.
Old Oct 6, 2014 | 08:38 PM
  #99
LsF-150's Avatar
Can anyone who has completed the swap verify they are getting the amount of timing, in the flex fuel adder table, actually added to total timing? I successfully added the sensor to a 2006 silverado and the commanded stoich is changing and the scanner pid "alcohol content" is reading 80% alcohol but the total timing has never budged from 16. Which is what is in the high octane table and what this truck has always ran. We have the bottom row of the "flex fuel" adder table populated with 3. Seems we should be seeing 19 degrees of timing.
Old Oct 7, 2014 | 04:20 PM
  #100
1FastBrick's Avatar
You did this on an 06 Silverado and used an 06 Silverado OS???
I ask because an 06 Silverado does not use a flex fuel sensor. It's based off 02 Sensor feedback.
