Need help getting the 5.3/Holley HP running
I have a 5.3 with the Holley EFI and I can only get the sucker to run for a few seconds and then she turns off. Fuel pressure is steady. Plugs are/were new. Seems like there's some miss-firing, although all the exh ports are hot. If I feather the throttle I can keep her running, but its rough. Wide band is reading over 20:1 due to a misfire I suppose. Wiring is all nice and done right. Where should I start?
If you can peddle it and make it start...
Then you might just need to open the throttle body blade a bit and reset the tps
Look at your iac values and see if its maxed out..
Also..you may just need a little more fuel in the fuel table.
Make sure you enable fuel learning to come on and do correction as soon as you start the car and it will atleast have a fighting chance by letting it correct the fuel on it's own while you work on other issues.
But ill bet it's mostly in the idle airflow / iac
Looked at a datalog and closed loop was at 100% when it was active. I held the throttle at 2500 rpms and the IAC was at 40% as called for when the TPS is above 0. AFR was at ~25:1. I couldn't get the engine hot enough for learning to engage as the coolant temp enrich was still active. Do I really want learning to engage in a case like this? I think the whole fuel table would get screwed up the way its running.
Last time I used this system on an lq4 it fired right up and idled perfect - something is up. Is there a way to see if the injectors are working properly with out sending them out?
For the sake of getting the vehicle to run on its own to trouble shoot.....yes. make it learn all the time until the first time it can get up to temperature and you can drive it down the road to get your fueling table closer.
Set the ect modifier table to 100 across the entire table temporarily.
Also, you can start by adding 20% to the entire fueling table.
To me..it seems that your datalog is saying you need more fuel...
Once you get the car to a warm temperature and have fueling in the ballpark.then you can go back and set ect modifiers back to other values and turn off learning for cold temps if you want.
I always let the ecu do closed loop fueling compensation until I have a known good fueling table.
Also... if you just took a file, and changed the map sensor to a 3 bar map..it does not change the fueling in the fuel table... you will have to do that manually...
In which case it means that your fuel table still has one bar map fueling #s in it even though it may read 3 bar map values in the side axis.
In which case...you need to add more fuel to the entire table.
Soundengineer - I want to thank you so much as she's now running!!! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
I had to add 30% to the base table to get to run, and you were correct about the map scaling throwing off the base fuel which I sorta figured would be an issue. Not sure why the software doesn't adjust that for you.
Its running, but rough. Not too bad, but I can tell something is off. Learning was engaged. After running it for ~20 min, CL compensation is still over 90% at idle. Sounds like a dead/lazy cyl. I really needed to crank in the idle set screw to get it to idle and it still needs a lot more, which makes me think a cyl is dragging. I have to get a thermal gun, but the exh mani's were all hot.
The best part is..because the fuel table us in lbs per hr, you wont gave to change anything to make it work exactly the same...
If you are using VE...click on conversion.. copy the whole table...then change the setting from ve to speed density, then paste those copied values into the fuel table.
Then change the injector values after that..
P.s. its always better to tune in lbs/hr..
Ve is just there for people who really have to have a ve table for some reason...like converting from other software programs.
