map sensor question
Old Jan 4, 2014 | 09:14 PM
x275radial's Avatar
Default map sensor question
heres my question, im doing a turbo 5.3 looking to run a 3 bar msd map sensor gm style. my question is when I get my comp flashed from psi is this something he tells the comp that it now hows a 3 bar map sensor, or is it something my tuner can do threw HPT's.. psi is doing my harness and comp start up flash. also not sure if this matters but I will still be running a MAF.
thanks
Old Jan 4, 2014 | 10:54 PM
FreshDA9's Avatar
You will have Map scalars that will need to be adjusted in your software to tell your pcm that you now have a 3bar. Depending on ecu (such as 0411) you could just run Speed Density and get rid of the maf if you wish.
Or you can Force maf (hoping you have a big enough maf) and not need to change from the one bar map sense it will not be used. LS7 slotted maf is a popular choice and can be scaled appropriately for the ecm you are using. Since you have the 3 bar i would still install it as its good to have a working map sensor if a maf ever fails.
Old Jan 4, 2014 | 10:57 PM
x275radial's Avatar
thanks for the reply.
Old Jan 5, 2014 | 01:51 AM
RonSSNova's Avatar
In the tune file, where are these MAP Scalars?
I'm not finding them.
Ok, answered my own question.
Engine Diagnostics/Airflow/Map Sensor
Ron
Old Jan 5, 2014 | 09:59 AM
soundengineer's Avatar
you will have to apply a 3bar OS to the stock file
and then the MAP will be scaled accordingly
you may have to adjust the map linear/offset values in the Engine Diagnostics/Airflow/Map Sensor
Old Jan 5, 2014 | 10:28 AM
x275radial's Avatar
also is this something to do threw hp tuners or something that psi will have to do when they flash my pcm to start off.
Old Jan 5, 2014 | 10:30 AM
you will do it thru HP tuners if PSI doesnt do it for you already
likely, PSI is either using HP Tuners or EFI live and adding a custom OS to your ECU already
you should talk to them and find out for certain what they are doing for your 3 bar MAP...ask for details...
if they arent putting in a 3 bar OS, then dont use them for tuning.
Old Jan 5, 2014 | 03:44 PM
x275radial's Avatar
thanks for the reply you very help full.
Old Jan 5, 2014 | 04:14 PM
ACCLR8N's Avatar
If the harness supplier flashes in a 3 bar OS with EFI-L, you won't be able to tune it with HPT. If they do use HPT, make sure they are not locking the tune if someone else is to tune it afterwards.
Old Jan 5, 2014 | 11:02 PM
FreshDA9's Avatar
r
This wont be necessary if he is running say a E38 or any other VVE ecm's. Thus he hasnt stated the ecm he is using. The VVE ecms already have tables for 1,2,3 bar and just need the map sensor scaled correctly.
As i stated above if he is running a 0411 then he should do (if he wants to), a COS and run full speed density. But it is dependent on the ecm and the tuner. MAF tunes are also good and do not need an upgraded sensor you just lower the maf switch point, or force the maf entirely (dependent on if the maf is big enough to support boost).
Old Jan 6, 2014 | 11:32 AM
x275radial's Avatar
well im using the factory 2001 Tahoe ecm. ill check the numbers on it.
Old Jan 6, 2014 | 02:34 PM
FreshDA9's Avatar
that is most likely a 0411 ecm. in which you will need to run a COS to properly scale the 3 bar.
I recommend you talk to your tuner and see if he feels comfortable about doing a speed density tune and getting rid of the maf.
Old Jan 6, 2014 | 08:41 PM
x275radial's Avatar
k will do. now if I remove the maf, when I go different places say upstate new York or over to atco in jersey will I have to retune the car or it will compensate for itself.
Old Jan 6, 2014 | 11:31 PM
FreshDA9's Avatar
Ok a little more in depth. you can physically remove the maf but you will need to replace it with an IAT sensor. Or you can leave the maf disable it in the software and use the IAT still built in. Typically with a blow off valve and a working maf you should not let the bov vent to atmosphere.
Running speed density the tuner will tune the map sensors cells for the volume-metric efficiency (fuel) table, and ignition tables. the ecm will use rpm, tps, ect, iat, and baro and fuel trims for compensations for weather and altitude changes.
Both maf or speed density tuning will allow the car to properly be calibrated. There are ups and downs to both but nothing drastic to sway an opinion. I personally like speed density tuning and you see most people with high end stand alone and big turbo cars such as Big Stuff 3, Holley, F.A.S.T., etc are using Map (speed density) tuning. But on the gen 4 ecms with VVE tables I strictly tune the maf cause those can be a real pain.
