Would new exhaust clear po151,po157,po131,po137?
Hey guys. I'm getting the above codes 151,157,131,137. Do you guys know if I put long tubes with new 02 sensors and delete the rear 02's if these codes will pretty much be taken care of? Thanks
Any ideas how I should go about solving this issue? My rear o2s will be gone after long tubes.
I also have the gm manual for my car, i will look up the procedure for this issue. Thank you for help Old G
I dont have own a programable tuner or anything like that. I can check the wiring for continuity and resistance, i havent dont that yet. If the wiring is fine and i install new o2s, what else do you think can cause thia code?
