Yank SS3600 stall converter tune
Hey guys,
I am in the process of installing my new Yank SS3600 Stall converter into my 2002 LS1 that has 3.73 gears and just a lid/catback
Couple questions as I try and get the tune ready for the stall converter that will likely be done by this weekend...
1) General Shift lock enable - from factory we have a setting that is "on" that allows the TCC to remain locked during a shift. Do I want to turn this option off or leave it as is? I remember when tuning my v6 that you did not want to be locking the converter when shifting unless you wanted to blow the converter apart??
2) Do we want to eliminate the TCC duty cycle? I know this is something we did in the v6 as with that car aftermarket converters didn't like to be slipped on and off, they liked either a solid on or off...?
3) Im guessing I'll need to adjust the apply /release of the converter -I think this is pretty straight forward...is this something that is common in the ls1 cars to?
4) I've read about tcc's locking and unlocking due to misfire counts- is this something a case learn would fix, or am I stuck changing the misfire numbers to #32767 ?
5) further to #4, if I do need to change those numbers, (under the engine misfire tab) am I changing them under revolution mode? cylinder mode? or both?
6) is there anything I missed / am unaware of?
Thanks to everyone in advance!!
Moderator
Lighter flywheel mass will change what the motor (PCM)
needs, to be stable. Probably for the worse. Expect it.
You do not want to lock through shifts.
You don't want to "eliminate" duty cycle. You want to
raise the minimum and maximum, to something like 98%
and 99%. This gives your TCC as much pressure as the
main trans pressure is delivering. That, in my book,
wants touching too.
Lighter converter mass elevates misfire detects. You
will probably need to raise the thresholds. If you just
doubled them, you might eliminate misfire-unlocking
but retain useful misfire detection for gross problems.
Me, I just jammed them all to 32767.
Part throttle shift tables and TCC apply/release need
to be set up for the changed slip behaviors. Rev limit
vs WOT MPH shiftpoints also.
wants touching too.
I haven't ripped full throttle on it yet since I just finally drove enough K's to break it in today, but it is pouring rain out...plus I still haven't had a chance to tune it yet...but surprisingly, no engine lights yet either.
Car feels totally different to drive, in my opinion it is 10000000 times better with a stall, it pulls beautifully under part throttle, you rip by cars entering the highway ramps at just 25% throttle and passing is even more of a joke since you're unlocking in a nice sweet spot.
Get one, I tell everyone to, it makes the car stupid fun to drive...the only thing I don't like about this stall (and my 6 didn't have this issue) is from a stop it almost doesn't want to move without very very light throttle...I think a tune can correct that as well as the car stalling under light stabbing of the throttle in reverse...I think the maf just needs to be recalibrated down low, and maybe bump the rpm up a little bit...I bumped up about 150rpm the other day and it corrected a bit of it, but it searches for idle under those reverse conditions...like I said, nothing a tune cant fix.
