Factory Tach is off
Crank sensor failing?
Power wire running to close to tach? *I added gauges WB and OP as well as a hard wire for my V1*
I know the signal wire is measured by Hertz so could it be interference? The tach used to show proper on my old motor. after building a new one its been off since the first start up.
yes i know the factory tachs arnt 100% accurate.. but it shouldnt show that high for an idle
Also I've no tach driven manual cars long enough that audibly I can confirm the engine is idling under 1000 so I know it's not the pcm reading wrong.
Our Gauges just read high. At some point if it gets worse I'll look into it. I just thank myself its not like the dashs on the third gen Camaro's. My buddies 88 Camaro tach reads 4k at idle :p
Maybe your buddy should try adjusting the tach output on HP Tuners if he is that far off. LOL
