Speedometer Output w/ Holley Dominator
Disclaimer: I have searched the interwebs for a few days and haven't found out how to output a speedo signal, only how to add a vss sensor to a vehicle without one....
LosLS2 you out there? Any help with this?
down to the pin you want to use when that's complete hit the done button at that point you have enabled the output to the pin you selected, Now you will need to know what signal your speedo is looking for, The manufacturer should be able to provide that information. You can change to those settings under the transmission tab also.
I'm new to this myself and what I have just told you is what I have figured out by playing around with the software to get familiar with it before I have the system installed, It should be enough to get you going in the right direction.
down to the pin you want to use when that's complete hit the done button at that point you have enabled the output to the pin you selected, now you will need to know what signal your speedo is looking for, the manufacturer should be able to provide that information. You can change to those settings under the transmission tab also.
good info!!!!!!
https://ls1tech.com/forums/conversio...l#post18815486
Andrew
