Why do motorcycle guys have auto tune but we don't?
Since I've gotten into building road racing bikes over the last year or two I've wondered more and more why there is noone making an auto tune for us. there are several options for the bikes that provide an auto tune or tune on the fly, why can't we have that, or is there something like that and I just don't know about it?
because ALL ECU's auto tune... its called Fuel trims...
GM chooses to use a narrowband o2 sensor, and only use them at part throttle and carry over positive trims to WOT...
Ford chooses to use a wideband o2 sensor, and fuel trims are used all the time
Moderator
The GM's auto-tune is pretty much limited to compensating for manufacturing tolerances, normal wear and typical fuel quality. Since the OP mentions "racing" he is probably referring to aftermarket cams, heads, intake, etc. If any motorcycle factory ECMs can auto-tune for such aftermarket parts, that would be very impressive. Of course motorcycles are not subject to the same stringent CAFE and EPA requirements.
Super Hulk Smash
VE and MAF tuning are essentially "auto tuned" in EFI Live and HPTuners. You hook up your wideband and use the data logging capability of the software to see how far off you are from commanded A/F. They provide the correction, you apply to the table, and presto, tuned.
Is the bike software doing this automatically?
I forgot I'd posted this... yes the bazzaz autotune as well as the dynojet will basically tune for whatever we do to the bikes. We change parts, change fuel, whatever, go out, run a few laps, come in, apply changes and BAM tune is typically spot on, if not, a few more laps and apply again and it's dead on. The bazzaz even has a switch we can switch between race gas and pump gas tunes.
Where efilive or hp tuners is actually modifying the tables inside the ecu itself. ON the bike tuners you are not changing anything from the factory, simply advancing the spark timing and increasing injector duty cycle for more fuel. The bike tuners are a very simple way to accommodate for aftermarket parts, once you drastically change a bikes engine though the limitations of these piggie back boxes are quickly found, as you have no adjust-ability on many tables you need.
btw, both hp tuners and efilive have a way to install a wide band and change your VE table, just like the auto tune does for the bike. Once setup you can take a car for a drive and it will recommend changes to your VE table.
Moderator
http://www.corvetteforum.com/forums/...hp-tuners.html
Perhaps better, here is a link to a .doc file detailing the procedure on an Gen4 FBody:
https://ls1tech.com/forums/attachmen...and_wo_eio.doc
Moderator
