Who is running ID1000 injectors?
Looking back at my logs, my IBPW values have not been identical bank to bank in open loop since I installed ID1000s. I was running low Z injectors with a driver box previously. I am seeing bank to bank differences of up to 2 msec or more. Logs confirm that no trimming is active. This has occurred with 2 different PCMs.
Has anyone else seen this with these injectors?
Yes have reset trims many times and just had the battery disconnected for a week. Don't know if there is any feedback from the injector circuits that might cause the PCM to vary the PW. Strange that I have seen it with 2 PCMs(first was a Roadrunner). So that leaves the injectors and the software. I`m running EFILive COS3, OLSD.
Well today I thought I would try a HPT tune, so I did a pre swap log first..and the damn IBPW values were identical. So I didn't change anything. Not counting on it staying this way though.
Now I just have to solve my throttle slamming shut momentarily(whiplash) when I hit it while already moving. (All TM is disabled.) This just started with the new torque converter, which transbrake stalls at 3800 rather than the spec'd 2600.
