Computer Won't Hold A Tune...HELP!!!
For one the engine conditions while doing a pull are not what it does 99.9% of its life and 2nd on a dynojet your only using about 4 or 5 of the 24 fuel trims so the tune NEVER sees most of the engine conditions so within a short time all those other conditions will delute/effect what little changes they did via the dyno.
I suggest you go to a real PCM tuner that adjusts for all driving conditions for once all fuel trims are adjusted properly they pretty well stay within a few % of where they were adjusted to.
The last tune I did on my car was over 1 year ago,
I monitored fuel trims for that year and they still are locked in where I adjusted them.
and "learns" its way back to what it "thinks"
is right. Then if it's correcting positive, this
ends up corrupting the WOT as well.
Just another reason to seize the power for
yourself instead of hiring it done (or half
done). Some of this stuff takes seat time
and road logging to uncover, understand
and fix.
Maybe you should think about what on the
car could account for a bad lean error. It
may be a tuning problem, but it all starts
with something that feeds bad data, or is
not living up to its computer table model's
expectations. What are your aftermarket
mods?
