Lean cruise
Mike454ss knows how much work I have done I'm the impala SS world and on lsx platforms.
of licensing (l have all years 4th gen Camaros enabled,
but will saying it's a Monaro then need me to license
a Monaro to edit it next time I open it)?
you aren't saying it is a monaro- you're telling the system the platform is "holden" none of your tables in the tune change, your vin stays the same
As a side note, will this enable lean cruise - no. For reasons outside my comprehension, HP Tuners is against enabling lean cruise (and changing some other attributes I won't cover) within our PCM's. I still like their product and use it almost daily.
As mentioned previously there are other ways to get lean cruise if you want it, you just have to be more... creative.
Jimmy, has no effect on licensing. That's tied to the VIN, not the platform code.
Now as I said...if it's a drive by wire solution...I leave the platform code and options matrix alone (so as not to disturb cruise control), and use the EFILive CAX "OS Hack"...when I do that, it does require a complete flash.
Since the platform code isn't a variable based on operation of the vehicle, it always fails if it's not V...
The 2004 GTO and all Holdens had the platform code set to V from GM...this is why you can just setup the other conditions in that car, and lean cruise works. If you change the platform code in an 04 GTO or any Holden, it will no longer be able to use lean cruise. Vice versa...if you change the platform code in any other vehicle to V, and copy the rest of the stuff over from a Holden, it will work. The system options matrix need to be set correctly as well or you'll have problems like your alternator won't charge and whatnot.
Now...what the EFILive CAX method does, that's different, is it "Hacks" the OS...so above where I said it checks platform code, vehicle speed, run time, and moving time, now instead it removes the platform code check from that loop...it only needs to pass the other checks.
Both methods work fine, and you get the same results...the difference is, the EFILive CAX method works in any vehicle, drive by wire or drive by cable without sacrificing cruise control, but it requires a full flash of the PCM because it's a modification to the OS, not to the calibration...and the platform code option (which you can do with TC, HPTuners, EFILive and maybe other software too) works in any cable throttle vehicle without issue, or any drive by wire vehicle without cruise control (but those are rare), and does not require a full flash as it's a modification to the calibration and not to the OS.
Ok, thanks, good explanation.
I take it P01 equates to LS1 with DBC, and P59 equates to LS1 with DBW...?
in EFILive these are both LS1B...?
I know P01 is part number 0411, what is P59...?
And FWIW, enabling LC with TC using the code patch leaves the platform code correct for the vehicle and requires a write entire or as TC calls it, Force Full Program.
And Joe, as he said, P01 is the 99+ red blue 512k LS1 pcm. The P59 is the blue green 1 meg pcm. Both were used in drive by wire and drive by cable vehicles, and both had multiple GM part numbers.
All of the P59 operating systems have and can use lean cruise. Only 2001+ P01 operating systems have it, so if you're trying to enable it in a 99 or 2000 car, you need to update the OS. If you want it in a 97-98 LS1 car you need to re-pin the harness for the newer hardware, which I think also requires a segment swap to make the gas gauge work in an F-body, not sure about a vette.
( EQR 1 is the stoich AFR, there is a setting in your tune file, probably either 14.63 or 14.68 )
so the LC multiplier (what is left after subtracting the 0.1) and the PE factor are EQR's... there is a pid EQIVRATIO that reports the commanded EQR (i.e. the final divisor).
In other contexts, FAR is 1/AFR.
I just got done looking at a holden Monaro LC tables that I will be using as a baseline. Looks like they are commanding as high as 17afr in some instances...I think I will massage this a little bit to go no more than about 16.3-16.5 at lean cruise. very interested to see what the aeroforce will report back for instantaneous mpg.
I know right now if I let off the throttle to go into dfco then lightly go back on the throttle just to maintain speed I can get steady readings of 32-33mpg at highway cruise speeds...
Thanks Joe- for some reason that tables explanation threw me for a loop
