Tune after getting head work done?
Old Sep 2, 2015 | 10:06 AM
JonRuh's Avatar
Default Tune after getting head work done?
I'm going to be doing head gaskets this winter and I was thinking about getting my heads ported and polished as long as the heads are off. Would I need to get a new tune for the car?
Old Sep 2, 2015 | 10:09 AM
thunderstruck507's Avatar
Yes, any time there are drastic changes to the airflow of the engine and most likely to compression you would want the tune at least checked...it will almost certainly need corrections.
Why are you planning to do head gaskets? Is there a problem?
Old Sep 2, 2015 | 10:11 AM
redtan's Avatar
Definitely gonna need a tune, you are significantly altering the amount of air going into the engine which will need compensating for.
Part throttle and idle might be ok if you have all the PCM sensors working, but full throttle will definitely need adjusting.
Old Sep 3, 2015 | 09:40 AM
JonRuh's Avatar
Looks like they are leaking already. Figured if I have them off might as well get them ported and polished. Not sure if its worth the money for what the gains might be.
Old Sep 3, 2015 | 10:36 AM
Darth_V8r's Avatar
Moderator
If you're going to have someone dremel them out, no. If you're going to send them off for a CNC job, I'd say yes. Up to you if it's worth the coin to have it done right. Probably gain about 30 or so from AI, PRC, TEA, etc
Old Sep 3, 2015 | 11:23 AM
redtan's Avatar
Also depends on who's holding the dremel in their hands. I'd let Mamo or Tooley dremel the **** out of my heads
Old Sep 3, 2015 | 01:28 PM
Darth_V8r's Avatar
Moderator
I hear you. Too many people ask "Cousin Verne" to do it. I have a true story on that from a friend and his home AC unit that was literally repaired by previous owner's cousin named Verne. So, it sort of stuck in our vocabulary as "Total Moron Hack Job". Seen a lot of stuff ruined that way over the years
Old Sep 3, 2015 | 05:33 PM
mrvedit's Avatar
Moderator
I think Livernois Performance in Detroit also has a CNC program for 243 heads.
Old Sep 3, 2015 | 07:15 PM
Darth_V8r's Avatar
Moderator
ten four. My lost wasn't meant to be exhaustive. Just trying to point in a direction
Old Sep 4, 2015 | 09:52 AM
LivernoisMotorsports's Avatar
You will need a good tune to ensure idle, throttle response, power and drive ability.
We offer dyno tuning (as well as remote tuning in certain cases)
installation
parts sales
cylinder head services CNC and custom
If your pulling them off, that is the time to upgrade.
