6.0 stuttering
Old Sep 16, 2015 | 03:45 PM
Jon Head's Avatar
Default 6.0 stuttering
I'm not sure if this is the right thread for this question but I need help. I have a 2000 chevy 2500 2wd and lately it's been a dog. Sometimes it will run just fine, other times when I hit the gas it stutters and doesn't want to move along with idling way down (It does the same when switched to neutral) eventually after holding down the gas pedal for long enough it will get its head out of its *** and want to move. What can I do?
Old Sep 16, 2015 | 03:55 PM
svede1212's Avatar
Scan for codes?
Old Sep 16, 2015 | 03:57 PM
Jon Head's Avatar
Only codes that popped was for a o2 sensor that's been there since I bought it 2 years ago
Old Sep 16, 2015 | 03:59 PM
Darth_V8r's Avatar
Moderator
Smoke test or WD40 test to look for vacuum leaks would be a good starting point. Worth checking plugs and wires, even though you're not getting misfire codes.
Old Sep 16, 2015 | 04:01 PM
Jon Head's Avatar
I replaced the plugs with delcos about a year ago but idk how old the wires are. I was told that a dirty throttle body can cause that. If I decide to clean it should I pull it off or just hit it with some carb cleaner and a brass brush?
Old Sep 16, 2015 | 05:49 PM
Darth_V8r's Avatar
Moderator
I'd pull it so that crud doesn't go into my intake
Old Sep 16, 2015 | 05:50 PM
Jon Head's Avatar
I'm going to go home and pull code on it again and it started acting really bad today
Old Sep 16, 2015 | 06:10 PM
Darth_V8r's Avatar
Moderator
What you're describing is classic vacuum leak behavior, though. Very difficult to run on little to no throttle (due to unmetered air, and therefore, underfueling) and it runs good at high RPM, due to unmetered air being a trace amount compared to the open throttle body.
A simple pinched injector o ring can cause that
Old Sep 16, 2015 | 06:12 PM
Jon Head's Avatar
I'll have to look into it. I thought it was something in the transmission for a good while lol
Old Sep 16, 2015 | 06:22 PM
Jon Head's Avatar
Oh I forgot to add it also stutters (sometimes violently) when shifting out of overdrive and into third
Old Sep 16, 2015 | 07:28 PM
Old Geezer's Avatar
There's a tune/diagnostics forum for threads like this ..
Old Sep 16, 2015 | 07:49 PM
Jon Head's Avatar
So it popped 3 codes
U1000- class 2 communication malfunction
P0512- starter request circuit
B1001- options configuration error
Old Sep 16, 2015 | 07:50 PM
Jon Head's Avatar
[QUOTE=Old Geezer;18967977]There's a tune/diagnostics forum for threads like this ..[/QUOTE
Like I stated in my original post I'm not sure if this is the correct place for this post. Everyone has been trying to help me figure this out up until you. If you don't like it then don't read it. Have a nice night.
Old Sep 16, 2015 | 08:29 PM
Darth_V8r's Avatar
Moderator
I'm not much help for that. I'm a M6 guy. I would think that's the torque converter locking mechanism, if a gun were to my head.
