Idling n RPM problems
Old Dec 5, 2015 | 10:01 AM
Hogsters's Avatar
Default Idling n RPM problems
Just recently my ls1 started idling differently with the rpms fluctuating up and down. Everything was fine last time I had started it so Im not sure what happened. I've replaced the plugs and Im about to replace the inline fuel filter... there was no change after replacing the plugs. At some points it just dies out, but I can easily start it back up. Anybody have an idea what might be going on?
Old Dec 5, 2015 | 11:57 AM
joecar's Avatar
May possibly have to clean and/or replace the IACV.
Also check for air leaks
Old Dec 5, 2015 | 03:38 PM
Hogsters's Avatar
Thanks for the feedback, I will try that and see if makes the difference. I'll post back with the results but probably wont be able to get to it till next week.
Old Dec 5, 2015 | 03:50 PM
LilJayV10's Avatar
Ahh scan for DTC's, look at fuel trims, check fuel pressure.
Old Dec 5, 2015 | 04:17 PM
Darth_V8r's Avatar
Moderator
Check for vacuum leaks also
Old Dec 5, 2015 | 04:43 PM
kingtal0n's Avatar
Right, all of that, and also check the line connecting your map sensor, sometimes the vacuum line develops a crack. If you are a maf sensor, then 2x boost leak test the system (even if you have no boost, a pressure leak test is still agreat way to ensure MAF sensor performance)
Old Dec 5, 2015 | 09:21 PM
Hogsters's Avatar
All sounds good, I'll start with these recommendations and post back with results. This forum rocks! Most of my Google searches lead back here.... lots of info and knowledge. Thanks for the feedback!
Old Dec 8, 2015 | 10:48 PM
Hogsters's Avatar
Boy was I wrong about the part prices. So I replaced the MAF with no results. I've ordered the IAC and will put the results up on Friday after I receive it.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Dec 8, 2015 | 11:05 PM
LilJayV10's Avatar
Keep on throwin' parts at it. you'll fix it eventually...maybe.
Old Dec 9, 2015 | 08:26 AM
Hogsters's Avatar
With these kind of prices I think Id rather find an air leak....lol. $120 for the MAF, $100 IAC, $180 EGR....
Old Dec 9, 2015 | 08:28 AM
Darth_V8r's Avatar
Moderator
Have any logs? In particular IAC counts and spark timing variability?
Old Dec 9, 2015 | 11:07 PM
LilJayV10's Avatar
that's what I'm saying. You would have been money ahead to take it to a shop and have them diagnose it or learn how to do it yourself.
If you have a scanner and/or data logger and can give some information about what's going on, people are going to be more willing to help you and you won't have to SWAG. Scientific Wild *** Guess.
Old Dec 9, 2015 | 11:24 PM
Arctic_Z's Avatar
I'm in the exact same boat. I haven't bought parts yet but I've cleaned everything listed above. Worst part is in the middle of troubleshooting for this issue the car doesn't want to start now. Battery is good, relays, starter, vats, fuel pump.. thinking about burning the car down.
Old Dec 10, 2015 | 08:38 PM
Hogsters's Avatar
Ok MAF replaced, IAC replaced and everything else cleaned. I cant run a OBD because of the engine swap from a Firebird to a jeep (it wasn't set-up) unfortunately. Will a shop run a diagnoses, tell me the problem and send me on my way to fix it? I did that once and not only was charged but was treated rudely.
Old Dec 10, 2015 | 11:09 PM
LilJayV10's Avatar
What are you using for an PCM? Is it stock and tuned with something like HP Tuners or aftermarket like Holley or MS3?
Old Dec 11, 2015 | 05:36 PM
Hogsters's Avatar
Ok so one last go around today and I find a little valve thingy that looks like it should have a hose connected to it but I cant find one, so I think maybe just maybe it suppose to have a rubber cap on it. (It's located on the back of the block in between firewall) So I find a rubber cap put it on and Wala! it runs great again!!! thanks to all those that chimed in, I 61 years old and still learning
What is the name of that thing anyways, what is it called and do?
[IMG][/IMG]
Old Dec 11, 2015 | 05:41 PM
Darth_V8r's Avatar
Moderator
Sounds like it could be the vacuum port to run your AC. Might want to verify your AC works and your vent controls work
Could also be your AIR system port, but I've not known that to cause idle issues. Just an annoying screeching sound
Old Dec 11, 2015 | 05:51 PM
Hogsters's Avatar
Never had AC, just a heater, could be why it was just capped off.
Old Dec 11, 2015 | 07:26 PM
joecar's Avatar
That's the vacuum port for the power brake booster.
Old Dec 11, 2015 | 08:33 PM
Hogsters's Avatar
So a vacuum port for the brake booster? So why is it capped off and how did that mess with my idle and rpms? Sorry maybe a dumb question but Im just trying to understand.
