Any pre-dyno tips?
I know the shorties are hurting me and so are the so-called high-flow cats. Even so, I should be getting higher numbers. The tuner is good at what he does and he's turned off the !AIR !EGR and the rear OS2 sensors. It' runs REALLY good, but the numbers totally suck. My tuner is going to re-dyno me Saturday. Several questions:
(1) Will completely sealing the blockoff plates and stopping the leaks net me any power at all?
(2) Will cleaning the MAF sensors, K&N filter, spark plugs or anything else net me anything?
(3) What can I do to get the max numbers from my dyno.
The only thing I know about the air/fuel ratio is that he said it was rich and he leaned it out for me. this guy used to work at Norris Motorsports, so, I would think he is pretty good. He is on this board and offers a lot of advice to other people who professionally tune LS1's here. His name here is TimZ28 and I looked at some of his replies and he seems to have all the answers that a lot of other tuners don't have. He's going to finish my dyno/tune up Saturday morning.
You convinced me. Since they're not too expensive, I'm gonna' order new TR55's tonight. The shorties is what are really killing me. I'll send you my numbers from last Saturday.
Oh yeah the temp was 90.36 degrees, pretty humid and in Central Florida ... not sure what the sea level is, but, it can't be very high here.
Thnaks for answering the post. I kept seeing people viewing, but, nobody is replying. Maybe I should have posted this in another thread???
I should be getting the FTRA kit. I think the only difference it will make is the cool air being drawn in from the concrete floor, instead of the un sealed and cutout bottom of the air box ... where the hot air was being drawn in from around the upper part of the engine (where the exhaust leak was).
This pull will be earlier in the morning and the air will be much cooler, so, I think that should help a little. I'm hoping that these things will all help me to break 340RWHP and gain a couple pounds of RWTQ.
As for 0-60 ft times, I haven't been to the dragstrip. Just guessing and seeing others' foot-times here, I would say that on street tires and no converter, I'm probably not under 2 seconds. I think where the shorties is helping, along with the TR220 cam, is on the low end, so, it's fairly possible, I could be getting 1-60 ft times of less than 2 seconds.
Man, I've got to get to the dragstrip soon. I'll post my numbers to you after the dyno this weekend and let you know if they are any better. I f you can think of anything that would help the numbers and the car, as well, I'll sure try anything about now. the guy that tuned my car said that because of the JBACat4ward headers an LS6 intake wouldn't do much for me.
Thnaks for your help 2x. If I can be of any help with your computer or anything, just let me know if you have questions. That's what I do for a living ... now that I left the Army ... kinda' funny that I was in the military and now do something as mild as fixing computers and doing networking stuff.
Again, thanks for the help ... hope to hear back soon from you.
The last dyno run had the A/F ratio at ~13.1. I think you are reversing the two curves on the printout. The baseline run was close to 14:1.
TR6s are not necessary for your combination. TR55s is the prefered plug but I would not expect to see significant gains by switching.
Tim
Anyway, the blockoff plate kit is installed now and the engine sounds nice and smooth ... no !EGR connection header leak ... no noise. The FTRA came in and was put on last night. I'm hoping that the early morning temps will help. The FTRA kit pulling cool air from the concrete floor area and the fact that the air box will be sealed/pressurized, well, I'm hoping to break above 340 RWHP. Hopefully, my numbers won't end up worse ...
I'm happy with the tune that was done by TimZ28. The car has excellent throttle response and pulls a lot harder ... low-midrange.
Here's what I am having him to change on Saturday:
(1) Set the shift point for 1-2 gear shifts higher to 6200 up from 5800.
(2) Increase the idle to 750 ... up from 600.
(3) Raise the rev limiter up to 6650.
(4) Possibly change the A/F just a bit. I'll guess I'll leave that to my tuner. Maybe he might want to lower it just a little bit????
Well, tell me what you think. Your input here is appreciated.
NOTE TO TIM: I know you can't spend much more time in it. Just a few minor changes, as we discussed last week, is all I expect ... and the dyno, of course ...
I don't have the sheet in front of me but I recall it picking up torque at the bottom end not losing it. If you gained 12 RWHP in the low to midrange area then you had to pick up torque. For example (20 ft-lbs * 3000 RPM) / 5252 = 11.4 HP.
As for the idle... it is currently set for 750 in P/N and 650 in gear. Are you having issues with the idle at those points?
Tim
RunFile_001.drf shows Max power = 333.97 Max Torque = 369.70 (red)
RunFile_003.drf shows Max power = 335.16 Max Torque = 349.58 (green)
The idle surges and dies at startup 2-3 times unless I sit and barely accelerate for about 20-30 seconds ... doesn't matter whether it's in P/N/Engaged. Tonight, I plan to drill a very small in the throttle body plate as others do with larger cams. I didn't think it would be necessary with a TR 220/220 .553/.553 112 LSA .cam ... maybe the Lobe Separation Angle needs it. I had understood you to say that the idle was set to 600 rpm as the last thing you said as I was leaving. I apologize if I misquoted you. I do remember you saying that it was set to 750 and thought it peculiar that you seemd to have quoted a different number later. My bad man ...
Since I fix the leakage of the blockoff plate, this idle issue seems to have improved to where it only dies once ... ocassionally twice, so it seems like maybe it's possibly something to do with VE tables vs A/F ratio. Just a stab ... know nothing about tuning ... obviously ... hahaha!
Thanks for keeping me straight Tim... gotta' have someone to keep me straight, I guess.
popocamaro2: Thanks for your input. I've decided to pull the TR6's and replace them. As for the temps, mine ran right dead center of the gage. Since the 160 Thermostat, it runs consistently about 15 degrees cooler. I've heard that if you run it too cool that it gums up the engine with varnish buildup. Is there such a thing as running TOO cool?
The IACs are where they should be. I need to work the PCM more on the starting. Is it hot or cold starts having the problem?Thanks,
Tim
Tim
I haven't ported the throttle body out any more. I'll buy 1 7/8" LTs' and an off-road pipe a few months down the road and then I'll have you tune it for me.
Well, I'll talk to you later, Tim. Thankfully, another weekend is nearly here.
