LS6 timing table
Old Apr 7, 2016 | 07:26 PM
cdmartin's Avatar
Default LS6 timing table
I have a recent build up and running. It is a late model 08 5.3 with 243 heads and a LS6 cam (the bigger one). Car is running on megasquirt. I have the car starting and running normal. I'm looking for a stock LS6 timing table to use for reference. Can anyone post their stock or mild upgraded timing table? Car will be tuned for 93 octane fuel. Trying to get 300rwhp, which I don't think will be an issue
Old Apr 7, 2016 | 09:27 PM
JakeFusion's Avatar
Super Hulk Smash
Code:
Labels	400	600	800	1,000	1,200	1,400	1,600	1,800	2,000	2,200	2,400	2,800	3,200	3,600	4,000	4,400	4,800	5,200	5,600	6,000	6,400	6,800	7,200	7,600	8,000
0.08	18.0	20.0	22.0	26.0	29.0	32.0	34.0	37.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0
0.12	18.0	20.0	22.0	26.0	29.0	32.0	34.0	37.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0
0.16	18.0	20.0	22.0	26.0	29.0	32.0	34.0	37.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0	40.0
0.20	18.0	20.0	22.0	26.0	29.0	32.0	34.0	37.0	38.0	39.0	39.0	39.0	39.0	38.0	38.0	38.0	38.0	38.0	38.0	38.0	38.0	38.0	37.0	37.0	37.0
0.24	18.0	20.0	22.0	26.0	29.0	31.0	32.0	34.0	35.0	36.0	37.0	37.0	37.0	36.0	36.0	36.0	36.0	35.0	35.0	35.0	35.0	35.0	34.0	34.0	34.0
0.28	18.0	20.0	22.0	26.0	28.0	29.7	30.0	31.0	32.0	33.0	34.0	35.0	35.0	35.0	35.0	36.0	36.0	35.0	34.0	34.0	34.0	34.0	33.0	33.0	33.0
0.32	18.0	20.0	22.0	24.6	26.7	28.5	30.0	31.0	32.0	32.5	32.0	34.0	38.0	34.0	33.0	32.0	31.0	31.0	32.0	31.5	31.0	30.0	29.0	29.0	29.0
0.36	17.0	19.0	20.6	22.5	24.6	26.2	27.6	29.0	30.0	30.5	31.0	32.0	36.0	34.0	32.0	31.0	30.0	33.0	31.0	30.5	30.0	30.0	29.0	29.0	29.0
0.40	13.0	15.5	17.8	20.5	22.5	24.5	26.5	28.0	29.0	29.5	30.0	30.0	34.0	34.0	31.0	31.0	29.0	32.0	31.0	30.0	29.0	29.0	28.0	28.0	28.0
0.44	7.0	10.0	13.0	16.6	19.2	21.6	24.0	25.9	27.0	28.0	29.0	30.0	32.3	32.0	31.0	30.0	29.0	32.0	31.0	29.5	28.0	27.0	26.0	26.0	26.0
0.48	4.0	7.0	11.0	14.2	18.0	20.0	22.3	24.1	25.0	26.5	28.0	28.0	32.0	32.0	30.0	30.0	29.0	31.0	28.0	28.0	28.0	27.0	26.0	26.0	26.0
0.52	1.0	2.0	7.0	12.0	14.0	16.0	20.0	24.0	24.0	25.5	27.0	28.0	32.0	32.0	29.0	30.0	29.0	28.5	28.0	28.0	28.0	27.0	26.0	26.0	26.0
0.56	0.0	1.0	6.0	11.0	13.0	15.0	18.0	22.7	24.0	25.0	26.0	28.0	32.0	31.3	29.0	30.0	28.0	26.0	26.0	26.0	26.0	26.0	25.0	25.0	25.0
0.60	-1.0	0.0	6.0	10.0	14.0	16.0	19.0	22.0	23.0	24.0	25.0	27.0	30.0	29.0	28.0	30.0	28.0	26.0	26.0	26.0	26.0	25.0	24.0	24.0	24.0
0.64	-1.0	0.0	6.0	10.0	14.0	16.0	19.0	21.0	22.0	23.5	25.0	26.0	30.0	29.0	26.0	28.0	26.0	26.0	25.0	25.0	25.0	24.0	23.0	23.0	23.0
0.68	-2.0	0.0	5.0	10.0	13.0	15.0	17.0	19.0	22.0	23.0	25.0	26.0	27.0	26.0	26.0	26.0	23.0	23.0	23.0	23.0	23.0	22.0	22.0	22.0	22.0
0.72	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	26.0	26.0	25.0	23.0	23.0	23.0	23.0	23.0	23.0	23.0	22.0	22.0	22.0	22.0
0.76	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	26.0	26.0	25.0	23.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
0.80	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
0.84	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
0.88	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
0.92	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
0.96	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
1.00	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
1.04	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
1.08	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
1.12	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
1.16	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
1.20	-3.0	-3.0	1.0	7.0	13.0	15.0	17.0	18.0	22.0	23.0	25.0	25.0	26.0	25.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0	22.0
Old Apr 8, 2016 | 04:49 PM
cdmartin's Avatar
Thanks for posting. I'll use that as a reference
Old Apr 8, 2016 | 10:47 PM
JakeFusion's Avatar
Super Hulk Smash
Np. It's from an 02 Z06. Should be a good starting point. It's actually not a bad timing table.
Old Apr 13, 2016 | 01:07 PM
gagliano7's Avatar
Here is one off a 2004 ZO6 HPtuners
Old Apr 13, 2016 | 01:11 PM
gagliano7's Avatar
Here is one from a 1999 camaro ss 6 speed. A little more aggressive than the ZO6
Old Apr 13, 2016 | 04:18 PM
JakeFusion's Avatar
Super Hulk Smash
I'd stick with the Z06 base. The 243s don't need 28 degrees of timing.
22 is a good starting point... it'll probably settle around 26 max.
Old Apr 13, 2016 | 08:39 PM
cdmartin's Avatar
Thanks for the sample tables guys. I'm driving the car around now trying to get the A/F dialed in decent. Then off to make a couple dyno pulls. I had the timing set on 20deg across the board as a safety. What a turd lol. Loaded the base Z06 table and it's MUCH better. Probobly try the camaro SS one too
