Need Tune File for LS3 GM Connect and Cruise Package
Just finished a connect and cruise and uses the T42. My LSA swap is running the E67 with the T42...
T,
T,
I am not understanding what your asking. What table do you want to see? I have tuned all of them using EFI Live. I have probably 20+ GM connect and cruises and they all had E67 ECM and a blue stand alone trans controller made by PCS and not a T42. The tables in the standalone controller are nothing like what's in a T42. The E67 doesnt talk to the PCS controller, it basically thinks it has manual trans behind it. The PCS controller is can see rpm, TPS, etc but doesnt talk to the E67. The tune is also a little different for the 430, 480 525hp LS3's and the LSA.
I have tuned a good number of E67/T42 swaps but they were done with aftermarket standalone harnesses and not the connect and cruise. They were either based off CTSV is it has a LSA or LS9 or TBSS OS's if it was NA and required alot of tuning for the swap application.
Look, I'm not here to debate controllers. I just installed a 480HP LS connect and cruise and it uses the T42. While you may have installed, or currently have a blue controller....great. They have been discontinued and are no longer being made. If your swap has one awesome, the architecture is no different than the T42.....So..back on track....
Does anyone have a tune file in HP Tuners for an LS3 they would be willing to share?
T,
T,
