Do I need to do a "crank relearn"? New LS6
That how ever is not causing the issue of running slower. Your old tune needs to be revised for your new combo.
What cam specs did you have before and what cam specs do you have now?
Thanks for any input.
Validated alignment of crank timing sprocket?
Main bearing clearance for cam and crank correct?
Head gasket thickness and bore clearance?
Intake gaskets?
