5.3 Swap Problems... PLEASE HELP
New plugs and wires
New Maf, MAP, and TPS sensors.
I have checked everywhere for vacuum leaks and replaced intake gaskets.
I have tried 2 sets of 02 sensors and my exhaust is fully welded with new manifold gaskets.
Compression is 120k on all cylinders
I have built 2 harnesses to make sure i did not have a break in a wire somewhere
I have 56PSI of fuel and the rails and checked injectors with noid light
I am at a loss here other than the rough idle the thing runs great. It does seem like i get high LTFT at around 8ish on both banks and 02s look to be functioning 0-850.
is there something that needs to be done in the tune so the computer knows there is no trans behind it. I have left the VSS sensor plugged wired into the computer, it is set up for a 4l60E. Could this be giving me a problem. Sorry for the long post i am just at a loss. My TPS bounces from 2-7 at idle but smooths out and stays steady when you hold the pedal at a certain spot.
Thanks for any help you could give
You may want to try open loop for now, unplug both O2 from harness and try again.
There are several things that can cause the rough idle, you need to check one by one. Lean mixture is the most frequent and it can be caused by a bad MAF, O2 sensors, untuned MAF tables etc.
For the Idle-In-Park Spark table, insert 18 or 20 (2 less) for the entire 0, 400 and 800 RPM rows.
For the High Octane Spark table, insert the same 20 or 22 for the top half of the 0, 400, 600 and 800 RPM rows. By top half I mean from 0.08 to .44 Cylinder Airmass.
Then insert about 10 in 1.20 column for those rows and blend the .44 to .120 columns.
Look at the Jake's tune in post #51 of this thread to get some idea of what I am suggesting:
https://ls1tech.com/forums/pcm-diagn...ng-stop-3.html
This should improve your idle. If it does, you should blend your 800 column into your 1000 and 1200+ columns; but that can wait.
Perhaps someone else has the time to look at your logs and make other/different suggestions. Sorry I've been busy lately.
