3bar upgrade.
Old Dec 17, 2016 | 11:02 PM
MY_2K_Z's Avatar
Default 3bar upgrade.
So the ecu in my Camaro is out of an 03 Tahoe and it has no 3bar upgrade available, only 2bar. I found a stock 03 Tahoe tune in the repository and it has 3 bar capability. My question is I've heard that if I license this tune from the repository that there could be some issues like vin/Os mis-match. Help me out guys how do I do this!!
Old Dec 17, 2016 | 11:06 PM
MY_2K_Z's Avatar
I also need to segment swap for 4l80e so not sure where that fits into this mess.
Old Dec 18, 2016 | 01:35 PM
truckdoug's Avatar
i've licensed tunes just swap OS's before
as long as the hardware number matches i think you're ok
Old Dec 18, 2016 | 03:01 PM
MY_2K_Z's Avatar
Bricked it lol. So now I need I new ecu. I think I will try to find an ecu out of a 2400hd that way it already has the 4l80e segment.
Old Dec 18, 2016 | 07:59 PM
truckdoug's Avatar
damn dude how did you manage that?
Old Dec 18, 2016 | 10:53 PM
MY_2K_Z's Avatar
Not sure lol. Plugged in the laptop and it wouldn't let me read the tune tried to rewrite it and it still wouldn't work. Oh well I'll go get another ecu this week. This time I'll make sure I get one with a 3bar enhancement available.
Old Dec 19, 2016 | 11:07 AM
Corner Worker's Avatar
If you have buy a new PCM and have to license a new OS anyway...go with a P59 PCM. Its a plug in play with your harness, offers 3 bar enhacement, and flex fuel. Just get an OS from an 03+ express van, should already have the 80e trans in it. Just segment swap the fuel gauge, and you are in. If you are using a 3.0 or greater version of HP tuners, you can segment swap yourself.
Just my unwanted opinion.
Old Dec 19, 2016 | 04:10 PM
MY_2K_Z's Avatar
Thanks for the heads up. I do want to change to a p59 just would prefer to get this thing running and all sorted before I add another point of complexity.
Old Dec 19, 2016 | 07:15 PM
Save yourself the credits and do it now. I just completed a swap on a 1998. Its no different with the tune. You still have to adjust the same settings.
Old Dec 19, 2016 | 07:54 PM
2xLS1's Avatar
An 03 Tahoe PCM would be a P59 and drive by wire. Blue/Green connectors. Are you sure you know what you have. Perhaps that is why you bricked your PCM.
Old Dec 19, 2016 | 08:23 PM
Yup.
MY_2K....Check the service# and hardware# on the PCM. Do some research around here and everything you need info wise is here. P59 is good, think about it, to have a 3bar, flex fuel vehicle is rad. Especially if you plan on running pump gas E85. It would be nice if your tune adjusted according to the true ethanol ratio.
Old Dec 19, 2016 | 08:59 PM
MY_2K_Z's Avatar
It was a p01 that's what it came up as was an 93 Tahoe p01
Old Dec 19, 2016 | 09:01 PM
MY_2K_Z's Avatar
And ya screw it I might as well. I'll try to locate one locally if not I'll just order one. Can you guys provide me with some numbers that I should be looking for on these pcms
Thanks for the input guys I really appreciate it
Old Dec 20, 2016 | 08:26 AM
read these:
https://ls1tech.com/forums/pcm-diagn...-write-up.html
https://ls1tech.com/forums/pcm-diagn...questions.html
https://ls1tech.com/forums/pcm-diagn...sor-fbody.html
https://ls1tech.com/forums/conversio...-6-0l-lq9.html
If you have any questions....just ask. I bought my P59 from eBay for $39
