Budget build advice needed
I'm looking for a way to control fuel and ignition on a budget in preparation for adding a turbo. I've been reading up on micro and megasquirt and they seem to be the most affordable way to go but wondering what some of you might recommend. Any input is welcome.
Email us for more info!
Rpmspeedtech@gmail.com
You can have a base tune put together on a micro setup in 30 minutes with just a few pointers.
That being said, I still prefer HPT and stock PCM to micro.
First off you "can" do more with hp tuners as you can tune any setup you put into that vehicle with that harness be it boosted, na, nitrous, etc. Or even if you were to swap to a newer gen engine and harness.
You do not have to pay over and over. Buying HP Tuners once gets you 8 credits. You can tune up to 4 individual vehicles that way OR use the credits in a different way and tune an unlimited amount of 99 camaros and have 2 credits left over. You can use them in many ways.
That being said, you do not have to use any credits to scan a vehicle. NEARLY ANY VEHICLE. You can also use HP Tuners to tune diesel trucks as well from ford dodge and gm and nearly all mid 00 and up gm, ford, and dodge vehicles. Hp tuners has so many updates available to work with all the newest vehicles out, as soon as you can buy a 2018 vette youll be able to tune it.
You can use any harness with it as well. Even from a junkyard.
The scanner has bidirectional controls that work on a variety of platforms, brands, vehicles as well.
Seriously the options are endless.
If its already wired and running then its a no brainer to just get HPT.
There are versions of MS3 that are far better than the stock PCM in almost every way. If it was between a stock PCM and an MS3 based build, MS3 would win hands-down.
