Attention - "!EGR" is a BAD thing!
See the excelent article in the June 2004 issue of Motor Age and the interesting letter by Al Cline of GM Powertrain in the August 2004 issue of Car Craft.
MRK
i put a post up asking about it, and just got laughed at... figured if i put the reasoning behind it, people would get totally confused.
https://ls1tech.com/forums/showthrea...&highlight=egr
Ryan
deleting it has no benefit to maximum power
output. Though the bit about shortening the
pipe in the throttle throat might pay off, some.
And the couple pounds saved equates to, what,
1/10HP
"depression" in the EGR-active region, this
may change your mixture some in the areas
where fuel calcs involve both MAF and SD
inputs (but, I do not know/understand where
this "blend" goes away, only that there are
some places where the fuel calc is not purely
MAF based). Compounding the problem is the
cam change from EGR to non-EGR years, that
messes around the VE too; so just using an
'01/'02 VE table would bring in its own bit of
error. But the -form- of the table should kinda
show how EGR / no-EGR profiles differ, where
the "EGR depression" lies.
Ryan
anyway so you have the option of just applying more
pedal without doing anything to hardware or software.
The "meatware" solution.
Chris
Ryan
That table is good info. It seems I pulled timing a bit too much after !EGR.
I already massaged that area in the VE table to adjust LTFTs. Though, I wasn't highly detailed with it and have not made absolutely sure of what changes did what... seemed to work as expected though. I plotted 3d graph from logs rounded to edit columns and rows... x-axis = map, y-axis = rpm and z = ltft ( average at that x-y point ) and adjusted the VE based in the area needing ltft corrections.
My 2001 didn't come with a EGR, so with that said, I guess GM engineers decided it was not needed after all.
MRK
To quote a passenger, "This car makes my eyes and nose burn."
