Throttle body not opening at launch
You would have to use HP Tuner to view my log and file.
https://www.hptuners.com/forum/forum...ine-Gas-(Gen-5)
https://www.hptuners.com/forum/showt...on-2017-C7-Z06
BTW, are you the Larry that sold the improved idler pulleys for the f-bodies many many years ago?
Yes, I'm that Larry! Sold a few more other than just idler pulleys too prior to 1998.
I thought so on the pulley. I'm still running one on my 99. If I remember you only made about 50 of them.
oil starvation needs disabled and you have to mod the DD and peak tq table correctly
the reason is takes so long to open TB 100% is due to not seeing enough tq
This is A table. There is also a C I would assume needs tweaking.
also increase Peak tq too
I can get the desired and actual throttle to match and go straight up when making a 100% pull (no delay)
peak tq in the lower RPMs will need more too..
notice the VSS is not in MPH (do the conversion in the scanner table)
the first column is very important in modding the 100% at 0mph or very low speeds...
also from the factory the DD table can cause tq management sparkncut with regular driving... fixing the really NEG values can fix that at low TPS throttle response
