Need to limit speed to 56mph 2001 ford escourt zx2
No joke ...
9 y/o kids oval track car. Track wants them all to be governed to 56mph
Currently everyone uses some type of throttle stop . Which severely limits acceleration .accelerator pedal only has about 1/4 of travel and car still goes over 56mph if the boy runs the outside groove... ...
Takes him a lap to get up to speed ...would be great if he could have full throttle to 56mph. any suggestions
A simple module that plugs into the obd2 port would be perfect ..
We have a spare ecm that could sent out to be tuned . Or would haul the whole car to someone in the New England area who could tune
Sorry if this is posted in the wrong section
Hook the PCM to a speedo signal from somewhere, calibrate, then adjust to 56mph governed speed. Gotta be some way to put a speed sensor somewhere to do this...
There can be a speed limiter parameter in the PCM calibration that at that speed cuts the fuel off at a set speed. You would need to find someone that has PCM tuning capability for that vehicle PCM (if it even exists) and see if there is a top speed limit in the calibration (if it exists).
"SCT Eliminator Switch Chip"
Same thing they used to tune all the foxbodies with. I believe it can do speed governing function and it should work with the escort. Call someone from SCT and pick their brain on the capability of this product
